Your basket is empty
Peerless-AV Arakno Heavy Duty Geared Projector Mount up to 56kg
Quicklinx: 9YXWWS00 Mfr#: PAG-UNV-HD
11 in stock
£124.36 ex VAT
£149.23 inc VAT
The Arakno Heavy Duty Geared Projector Mount is engineered for compact strength, with a capacity to hold a hefty 125-lb multimedia projector. This projector mount boasts premium adjustability and enhanced functionality. An integrated quick-connect mechanism makes projector attachment or removal easy, while its patented gear technology makes fine-tuning the projector image a cinch.
Peerless Arakno Heavy Duty Geared Projector Mount PAG-UNV-HD - mounting kit
Mounting kit - ceiling mountable
Mounting Components
Ceiling plate, adapter plate
Adjustable Width
21.6-44.8 cm
Adjustable Depth
19-23.3 cm
Adjustable Height
21.6-44.8 cm
1.8 kg
North America
Recommended Use
Projector
Max Load Weight
57 kg
5 years warranty
Adjustable Width
21.6-44.8 cm
Adjustable Depth
19-23.3 cm
Adjustable Height
21.6-44.8 cm
1.8 kg
North America
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Max Load Weight
57 kg
Quick release, scratch-resistant
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 100 - 150
