The Arakno Geared Projector Mount is designed with superior grip adjustment knobs to deliver the easiest fine-tuning for precise image alignment. Compatible with virtually any projector weighing up to 50 lb it is the easiest, most installer friendly-mount for any application. The ultimate solution for convenient and secure projector installation for ceiling applications.
- Peerless Arakno Geared Projector Mount PAG-UNV - mounting kit - for projector - black
- Product Type
- Mounting kit - ceiling mountable
- Mounting Components
- Ceiling plate, adapter plate
- Adjustable Width
- 21.6-44.8 cm
- Adjustable Depth
- 11.4-18.1 cm
- Adjustable Height
- 21.6-44.8 cm
- 1.4 kg
- Localisation
- North America
- Recommended Use
- Projector
- Max Load Weight
- 22 kg
- Black
- 5-year warranty
- Adjustable Width
- 21.6-44.8 cm
- Adjustable Depth
- 11.4-18.1 cm
- Adjustable Height
- 21.6-44.8 cm
- 1.4 kg
- Black
- Localisation
- North America
AV Furniture
- Mounting kit
- Recommended Use
- Projector
- Placing / Mounting
- Ceiling mountable
- Max Load Weight
- 22 kg
- Quick release, scratch-resistant
- Limited warranty - 5 years
