Creating a 2 x 2 video wall is simple and cost effective with the Peerless-AV DS-VWS546-2X2 Floor Stand Video Wall Mount. The single frame design easily clamps to the stand uprights making it ideal for Rental and Staging applications. The universal adaptors accommodate displays measuring 40"-46" and place displays on the same vertical plane. Once the displays are mounted, the built in horizontal adjustment leaves a seamless appearance.
- Peerless-AV Floor Stand Video Wall Mount DS-VWS546-2X2 stand - for 4 LCD displays - black powder coat
- Product Type
- Stand - floor-standing
- 181.7 cm x 91.4 cm x 183.7 cm
- Recommended Use
- 4 LCD displays
- Recommended Display Size
- 40"-46"
- VESA Mounting Interface
- 200 x 200 mm, up to 800 x 400 mm
- Max Load Weight
- 272 kg
- Black powder coat
- 5-year warranty
- 181.7 cm
- 91.4 cm
- 183.7 cm
- Black powder coat
AV Furniture
- Stand
- Recommended Use
- 4 LCD displays
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- 40"-46"
- Max Load Weight
- 272 kg
- Adjustable height
- Limited warranty - 5 years
