PCTV systems nanoStick 292e DVB-T2 tripleStick HD TV Tuner
Quicklinx: 77KGWS00 Mfr#: 23076
The world's first DVB-T2 receiver turns your PC into a Freeview HD PVR!
PCTV nanoStick T2 is the world's first DVB-T2 receiver and turns your PC and laptop into an HDTV PVR. The included TVCenter application lets you time shift and record TV shows and even stream Live-TV and TV recordings to your iPhone, iPad or other PCs and Macs. PCTV nanoStick T2 is fully backward compatible to DVB-T and delivers outstanding reception for both standards. Other features include extra-fast Teletext and support for Windows Media Center (DVB-T only). DVB-T antenna, USB extension cable and mini remote control are included.
PCTV nanoStick T2 is a compact USB tuner for the next gen digital terrestrial TV (DVB-T2). Now you can watch, time shift and record free HDTV (Freeview HD) in perfect picture quality on your PC and laptop.
PCTV nanoStick T2 also supports SDTV reception (DVB-T) and its streaming from a Windows PC to an iPhone or iPad. TV recordings with nanoStick T2 on your hard disk can be scheduled and played back from these mobile devices as well as from any PC or MAC via its web browser - never miss your favourite TV show.
Package Contents
  • USB 2.0 TV tuner for DVB-T2, DVB-T,
  • Mini remote control (battery included)
  • DVB-T antenna
  • USB extender cable
  • CD with TVCenter application, drivers and user manual
  • Quick start guide
Minimum System Requirements
  • Microsoft® Windows 7® or Windows Vista with latest Service Pack, 1 GB RAM
  • Or Windows XP (32 bit) with latest Service Pack, 512 MB RAM
  • PC with 1.5 GHz processor for SD TV
  • For HDTV: 2,6 GHz multi core processor
  • Hard disk with min. 1 GB free capacity (20 GB free capacity recommended)
  • Sound and graphics with support for DirectX® 9 or higher
  • USB 2.0 port
  • CD/DVD drive for software installation
  • Internet connection for software
Important notes on DVB-T/T2 reception:
Please ask your dealer whether DVB-T is available in your region. DVB-T reception is depending on location and might be impaired by thick or steel-enforced walls, and high neighbouring buildings. In such environments, an outdoor / roof-top DVB-T antenna is required. Mobile reception of DVB-T, e.g. in a car or train, is in general not possible.
Please check the Freeview HD coverage at your home here: http://www.freeview.co.uk/HD
PCTV tripleStick - digital TV tuner - USB 2.0
Digital TV tuner - DVB-C, DVB-T2
Interface Type
USB 2.0
Included Input Adapter Accessories
Remote control, MCX to IEC antenna adapter, antenna
Digital Video Format
MPEG-1, MPEG-2, MPEG-4, H.264
Audio Input Support
Standard
Sound Input Mode
Stereo
Remote control
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
Interface Type
USB 2.0
Video
Audio Input Support
Standard
Remote control
Audio Input
Digital radio tuner
Sound Input Mode
Stereo
1 x TV antenna - input - MCX
1 x USB 2.0 - 4 pin USB Type A
1 x USB extension cable - external
Software Included
Drivers & Utilities, PCTV TVCenter
System Requirements Details
Dual core processor - 1.5 GHz - RAM 1 GB - HD 1 GB
Resources
The following resources are available for the PCTV systems nanoStick 292e DVB-T2 tripleStick HD TV Tuner
