FUEL Active is the perfect go anywhere mobile rechargeable battery designed for outdoor enthusiast. Built in a high impact, element-resistant housing; FUEL Active provides a powerful battery and LED flashlight to keep devices powered up while camping, hiking, boating or just on-the-go in the city.
Perfect for devices including smartphones, cameras, and GPS units; FUEL Active has built in protection against overcharge, under discharge, over-current, over temperature protection, and short circuit protection to keep these devices protected while in use. FUEL Active also features power pass through technology enabling the battery to be charged when plugged in to a USB or wall outlet, while charging devices.
- Patriot FUEL Active power bank - Li-Ion - USB
- Product Type
- Power bank
- 2.13 cm x 10.74 cm x 2.13 cm
- 72 g
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1 A
- Battery
- Lithium Ion - 2000 mAh
- Cables
- Micro-USB to USB cable
- 1-year warranty
- Product Type
- Power bank
- 2.13 cm
- 10.74 cm
- 2.13 cm
- 72 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 1 A
- Short circuit protection, overcharging protection, overheat protection, over-current protection, built-in flashlight, overdischarging protection
- Technology
- Lithium Ion
- Capacity
- 2000 mAh
- Charged
- Cables Included
- FCC, RoHS
- Limited warranty - 1 year
