Parrot Minidrone Jumping Sumo Insectoid - Black
Quicklinx: BL43WS00 Mfr#: PF724001AA
More than just an RC car the Jumping Sumo Mini Drone from Parrot can perform acrobatics including half- and U-turns cruise at up to 4. 5 miles per hours and jump up to 31. It is controlled using the Parrot Free Flight 3 app with a smartphone or other Wi-Fi enabled mobile device available separately. A built-in 640 x 480 resolution 15 fps camera allows you to see a first-person view as the Jumping Sumo rovers around. Plus a USB port on top allows you to connect a flash drive to make a video recording of your adventures. Two wheel settings allow you to choose between a wide stance for speed and stability or a narrow stance for maneuverability.
  • Perfect jumps
    Parrot Jumping Sumo is a responsive bot with a strong personality which rolls, rushes, zig-zags, circles, takes turns at 90°. In a flash, it leaps up to 80 cm in height!
  • Jump and roll
    Its ultra sophisticated technology enables more precise turns than any radio-controlled car. Drive with your fingertips. Jumping Sumo performs half- and u-turns in less than a second with its inertial unit. Depending on your driving, it expresses his mood with customizable sound animations! As soon as you take it in your hands, LED turn red informing jump is disabled.
  • Faultless directional stability
    2 piloting experiences with Jumping Sumo adjustable wheels: the wheels open for greater stability in high-speed; re-tract in "compact" mode to enhance agility and drive through narrow areas. Its embedded technology ensures perfectly straight paths and extreme turns!
  • The world in immersive view
    Parrot Jumping Sumo is equipped with a wide angle camera that streams live immersive views on the piloting screen. You discover the world at the height of your Jumping Sumo and explore inaccessible areas.
Parrot MiniDrones Jumping Sumo - bot
