The fastest, easiest, most powerful way to run Windows on your Mac—without rebooting!
Use Internet Explorer®, Windows Media Player, Access®, and hundreds of other applications not available on the Mac.
Run Windows and Mac applications side-by-side
Choose your view to make Windows invisible while still using its applications, or keep the familiar Windows background and controls on your Mac.
Now Supporting Windows 10 and Ready for El Capitan
Run Windows® 10 on OS X® El Capitan with ease. Use Microsoft Cortana, your virtual assistant, on your Mac.
Switch from your PC to your Mac
We make it easy to get all of your files, applications, browser bookmarks, and more from your PC to your Mac; just follow the setup assistant.
Not just for Windows
Run a wide array of operating systems including OS X, Windows 10, 8.1 & 7, Linux, and Google ChromeTM. You can run just about anything on your Mac!
Works with Boot Camp®
Reuse your existing Boot Camp installation. Converting a virtual machine from Boot Camp is now much easier and more intuitive than ever.
Seamless Integration
Launch Windows apps from the Dock, use OS x gestures in Windows apps, and copy & paste and drag & drop between Mac and Windows.
One-click tuning
Select productivity, games, design, or development, and Parallels Desktop 11 for Mac will optimize your virtual machine settings and performance for you.
Always on Cortana®
Brings Windows goodness to Mac. Use Cortana, the Microsoft speech enabled virtual assistant, even when Windows 10 is not the forefront application.
Parallels desktop
The easiest, fastest, and most powerful solution for running Windows applications on a Mac without rebooting. -
Mac coolness in Windows Apps
Launch Windows Apps from the dock, use OS x gestures in Windows Apps, and copy & paste and drag & drop between Mac and Windows. -
Easy to get all of your files, applications, browser bookmarks and more
It is easy to get all of your files, applications, browser bookmarks and more from your PC to your Mac. Just follow wizards. -
Powerful performance
Support for CPUs and RAM lets you run even the most demanding applications with ease. It won't slow you down. -
Run any Windows Apps on Mac
Use Internet Explorer, Windows Media Player, Access and 100s of other applications not available on the Mac. -
One click tuning
Automatically tune it for what you'll use it for the most: productivity applications, design, development or games. -
It's not just for Windows
Support for running a wide array of operating systems including OS X Mavericks, Windows 8.1 & 7, Linux and Google Chrome means you can do just about anything on your Mac. -
Ready for OS X Yosemite
It's excited about the upcoming Yosemite release. The engineers are hard at work making sure that the Yosemite coolness to Windows Apps too!
- Parallels Desktop for Mac (v. 11) - box pack - 1 user
- Product Type
- Box pack
- Category
- Utilities - desktop virtualisation
- Version
- 11
- Licence Qty
- 1 user
- Platform
- MacOS
- Category
- Product Type
- Box pack
- Version
- 11
- Platform
- MacOS
Licencing
- Licence Qty
- 1 user
