By simply mounting the VW-CLT2 3D Conversion Lens, you can record Full HD 3D images with the MVC (Multiview Video Coding) recording system of the AVCHD 3D format.
- Panasonic VW-CLT2E-H - converter - 33 mm
- Lens System
- Converter
- Intended For
- Camcorder
- Lens Aperture
- F/2.0
- Focal Length
- 33 mm
- Optical Zoom
- 1.5 x
- Min Focus Distance
- 1 m
- Special Functions
- 3D
- 189 g
- Designed For
- Panasonic HC-V700, HC-V700M, HC-V707, HC-X800, HC-X900, HC-X900M, HC-X909, HC-X920, HC-X929
- Diameter
- 8.2 cm
- 7.3 cm
- 5.9 cm
- 189 g
Lens System
- Converter
- Special Functions
- 3D
- Intended For
- Camcorder
- Focal Length
- 33 mm
- Lens Aperture
- F/2.0
- Optical Zoom
- 1.5 x
- 1 m
- Included Accessories
- Dust cap, storage bag, adaptor ring
- Designed For
