4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs.
With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro Engine are on hand to tease out every last tiny detail 4K has to offer.
4K source material required for optimal picture quality
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs. -
Delivers four times the picture resolution of a normal HD TV
With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro Engine are on hand to tease out every last tiny detail 4K has to offer. -
Accurate picture quality as the director intended
The panel is the canvas and the processor is the artist. Panasonic's 4K Studio Master Processor contains unrivaled picture processing knowhow from the reference-quality plasma TVs and teh professional AV products, to deliver the best possible picture quality true to the director's intentions. Together with the Wide Color Phosphor technology, it ensures accurate colors, fine blacks and brilliant brightness. -
Enjoy rich, natural black colors and greater shadow detail
LCD TVs usually create pictures with just a few lights all running at the same brightness, making it hard to deliver convincing black colors and sufficient detail in dark areas. Local Dimming Pro, though, provides individual control over a large array of LED lights behind the screen, greatly enhancing contrast. What's more, dozens of picture 'zones' are analyzed and adjusted separately to boost shadow detail.
- Panasonic TX-65CR730B VIERA CR730 Series - 65" LED-backlit LCD TV - 4K
- Product Type
- Curved LED-backlit LCD TV - Smart TV
- Diagonal Class
- 65"
- Metal silver
- Platform
- Firefox OS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- 4K 1000 Hz BMR Intelligent Frame Creation
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- LED backlight local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, Amazon Video, FREETIME, Freeview Play
- Multi-channel Preview
- Picture-and-text (PAT)
- Picture Enhancements
- Bright Panel Plus
- Speaker System
- 2 speakers
- Sound Effects
- VR-Audio True Surround
- Supported Memory Cards
- SD Memory Card
- USB
- 3 ports
- Included Accessories
- Remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 139 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 193 kWh
- Dimensions (WxDxH) - without stand
- 145.4 cm x 14.3 cm x 85 cm
- 31.5 kg
- Curved Screen
- Product Type
- Energy Class
- Class A
- 139 W
- 193 kWh
- Diagonal Class
- 65"
- Series
- VIERA CR730 Series
- Platform
- Firefox OS
- Video Processor
- Quad-Core Pro
- TV Tuner
- TV Tuner Presence
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Modes
- Game mode, hotel mode
- Bright Panel Plus
- Dimensions
- Without stand
- 145.4 cm
- 14.3 cm
- 85 cm
- 31.5 kg
- Enclosure Colour
- Metal silver
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Display Menu Language
- English
- Brilliant Contrast, My Stream, Voice Assistant, 4K Pure Direct, TV Anywhere, My Home Screen 2.0, Easy Mirroring, Info Frame
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Metallic
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-T, DVB-T2
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 1500 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- VP9
- SD Memory Card
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Voice Guidance
- Speakers
- 2 x main channel speaker - 10 Watt
- Driver Details
- Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Encryption
- DTCP-IP
- Connect & Share
- Swipe & Share
- Supported Consumer Electronics Control (CEC)
- VIERA Link
- DLNA
- Connector Type
- HDMI input - side , 2 x HDMI input - bottom , USB 3.0 - side , 2 x USB 2.0 - side , LAN - rear , SCART - rear , Composite video / component video input - rear , Digital audio output (optical) - bottom , Headphones - side
- IEC 62087 Edition 2
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0.25 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.4 cm x 14.3 cm x 85 cm x 31.5 kg , Panel with stand - 32.5 kg
- Width (Shipping)
- 167.6 cm
- Depth (Shipping)
- 30.5 cm
- Height (Shipping)
- 97.3 cm
- Weight (Shipping)
- 42 kg
