Your basket is empty
Panasonic TX-65CR730B 65" 3840x2160 HDMI USB 4K Ultra HD LED TV
Quicklinx: C84WWS00 Mfr#: TX-65CR730B
  • DVB-T
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs.
With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro Engine are on hand to tease out every last tiny detail 4K has to offer.
Panasonic TX-65CR730B VIERA CR730 Series - 65" LED TV
Curved LED-backlit LCD TV - Smart TV
Diagonal Class
65"
Metal silver
Platform
Firefox OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
2160/50p, 2160/60p
Motion Enhancement Technology
4K 1000 Hz BMR Intelligent Frame Creation
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
LED backlight - local dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-T, DVB-T2
Internet Streaming Services
Netflix, Amazon Video, FREETIME, Freeview Play
Multi-channel Preview
Picture-and-text (PAT)
Commercial Features
Hotel mode
Picture Enhancements
Bright Panel Plus
Speaker System
2 speakers
Sound Effects
VR-Audio True Surround
Supported Memory Cards
SD Memory Card
USB
3 ports
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
Power Consumption (On mode)
139 W
Energy Consumption per Year
193 kWh
145.4 cm x 14.3 cm x 85 cm
31.5 kg
Curved Screen
Energy Class
Class A
139 W
193 kWh
Diagonal Class
65"
Series
VIERA CR730 Series
Platform
Firefox OS
TV Tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Modes
Game mode
Bright Panel Plus
Dimensions
Without stand
145.4 cm
14.3 cm
85 cm
31.5 kg
Enclosure Colour
Metal silver
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Display Menu Language
English
Commercial Features
Hotel mode
Brilliant Contrast, My Stream, Voice Assistant, 4K Pure Direct, TV Anywhere, My Home Screen 2.0, Quad-Core Pro processor, Easy Mirroring, Info Frame
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Metallic
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-T, DVB-T2
Video Features
Input Video Formats
2160/50p, 2160/60p
Teletext
Teletext Memory
1500 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
VP9
SD Memory Card
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Audio System
Digital Audio Format
Dolby Digital Plus output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Audio Return Channel (ARC), Voice Guidance
Speakers
2 x main channel speaker - built-in - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Encryption
DTCP-IP
Connect & Share
Swipe & Share
Supported Consumer Electronics Control (CEC)
VIERA Link
DLNA
Connector Type
HDMI input - side , 2 x HDMI input - bottom , USB 3.0 - side , 2 x USB 2.0 - side , Network - rear , SCART - rear , Composite video / component video input - rear , Digital audio output (optical) - bottom , Headphones - side
IEC 62087 Edition 2
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.25 Watt
Dimensions & Weight Details
Panel without stand - 145.4 cm x 14.3 cm x 85 cm x 31.5 kg , Panel with stand - 32.5 kg
Width (Shipping)
167.6 cm
Depth (Shipping)
30.5 cm
Height (Shipping)
97.3 cm
Weight (Shipping)
42 kg
