Panasonic TX-55CR852B 55" 3840x2160 HDMI USB 4K Ultra HD LED TV
Quicklinx: C84RWS00 Mfr#: TX-55CR852B
  • DVB-T
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs.
With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro Engine are on hand to tease out every last tiny detail 4K has to offer.
  • 4K source material required for optimal picture quality
  • Delivers four times the picture resolution of a normal HD TV
  • Accurate picture quality as the director intended
    The panel is the canvas and the processor is the artist. Panasonic's 4K Studio Master Processor contains unrivaled picture processing knowhow from the reference-quality plasma TVs and teh professional AV products, to deliver the best possible picture quality true to the director's intentions. Together with the Wide Color Phosphor technology, it ensures accurate colors, fine blacks and brilliant brightness.
  • Enjoy rich, natural black colors and greater shadow detail
    LCD TVs usually create pictures with just a few lights all running at the same brightness, making it hard to deliver convincing black colors and sufficient detail in dark areas. Local Dimming Pro, though, provides individual control over a large array of LED lights behind the screen, greatly enhancing contrast. What's more, dozens of picture 'zones' are analyzed and adjusted separately to boost shadow detail.
Panasonic TX-55CR852B VIERA CR852 Series - 55" LED-backlit LCD TV - 4K
Curved LED-backlit LCD TV - Smart TV
Diagonal Class
55"
Dark silver metal
3D
3D Technology
Active
Platform
Firefox OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
2160/50p, 2160/60p
Frame Rate & Enhancement Technology
4K 1600 Hz BMR Intelligent Frame Creation
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
LED backlight local dimming pro
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Netflix, Amazon Video, FREETIME, Freeview Play
Multi-channel Preview
Picture-and-picture (PAP), picture-in-picture (PIP), picture-and-text (PAT)
Picture Enhancements
Wide Colour Phosphor Panel, Supreme Contrast, Dynamic Range Remaster
Speaker System
2 speakers, 2 woofers
Sound Effects
VR-Audio Master Surround 2.1
Supported Memory Cards
SD Memory Card
USB
3 ports
Remote control, touchpad remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class B
Power Consumption (On mode)
137 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
190 kWh
123.6 cm x 12.4 cm x 72.7 cm
23.5 kg
Curved Screen
Energy Class
Class B
137 W
190 kWh
Diagonal Class
55"
Series
VIERA CR852 Series
3D
3D Technology
Active
Platform
Firefox OS
Video Processor
4K Studio Master
TV Tuner
TV Tuner Presence
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Modes
Game mode, hotel mode
Dimensions
Without stand
123.6 cm
12.4 cm
72.7 cm
23.5 kg
Enclosure Colour
Dark silver metal
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Display Menu Language
English
My Stream, Voice Assistant, 4K Pure Direct, TV Anywhere, Studio Master Color, My Home Screen 2.0, Quad-Core Pro processor, Easy Mirroring, Super Bright Panel, Info Frame, 4K Studio Master Processor
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Dark metal
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
2160/50p, 2160/60p
Teletext
Teletext Memory
1500 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-4, WMV, AVI, MKV, VOB, FLV, AVCHD, TS, 3GPP, PS, M4V, VRO, HEVC, VP9
Supported Audio Formats
MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), Apple Lossless
Supported Pictures Formats
MPO, JPEG
SD Memory Card
USB Port
USB Ports Qty
3
Remote Control
Remote control
Additional remote control included
Audio System
Digital Audio Format
Dolby Digital Plus output
Surround Mode
Sound Effects
Speaker System
Output Power / Total
40 Watt
Audio Return Channel (ARC), Voice Guidance
Speakers
2 x main channel speaker - 10 Watt , 2 x woofer - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Encryption
DTCP-IP
Connect & Share
Swipe & Share
Supported Consumer Electronics Control (CEC)
VIERA Link
DLNA
Connector Type
HDMI input - side , 2 x HDMI input - bottom , USB 3.0 - side , 2 x USB 2.0 - side , LAN - rear , SCART - rear , Composite video / component video input - rear , Digital audio output (optical) - bottom , Headphones - side
Touchpad remote control
IEC 62087 Edition 2
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption (Off Mode)
0.25 Watt
Dimensions & Weight Details
Panel without stand - 123.6 cm x 12.4 cm x 72.7 cm x 23.5 kg , Panel with stand - 123.6 cm x 27.5 cm x 76.4 cm x 26 kg
Width (Shipping)
145.9 cm
Depth (Shipping)
29.9 cm
Height (Shipping)
84.3 cm
Weight (Shipping)
33 kg
