Panasonic Toughpad FZ-G1 Intel Core i5-6300U 4GB 128GB 10.1" Windows 10 Professional 64-bit
Quicklinx: C6DKWS00 Mfr#: FZ-G1R0008TE
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
The fully rugged Toughpad FZ-G1 tablet with Windows 10 Pro sets the new benchmark for outdoor viewable tablets making it ideal for field workforces in outdoor scenarios. With its capacitive, 10-finger multi-touch display and digitizer pen and flexible configurable ports this device can be used to view high definition documentation and images in the field whilst benefitting from connectivity options to ensure data is always available when needed. The flexible configuration port gives business users the legacy port options they require in a compact, fully rugged and lightweight form factor.
Panasonic Toughpad FZ-G1 - 10.1" - Intel Core i5 - 6300U - 4 GB RAM - 128 GB SSD
Tablet - rugged
Operating System
Win 10 Pro
Intel Core i5 (6th Gen) - 6300U / 2.4 GHz, up to 3 GHz / 3 MB Cache
4 GB DDR3L
Storage
128 GB SSD
Display
10.1" touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
Up to 14 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
27 cm x 18.8 cm x 1.9 cm
1.1 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 3 years
Tablet - rugged
Operating System
Windows 10 Pro
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6300U / 2.4 GHz
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel vPro Technology, Intel Smart Cache
RAM
4 GB
Max RAM Supported
8 GB
DDR3L SDRAM
Storage
Main Storage
128 GB SSD SATA
Display
10.1" - IPSa
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Brightness
800 cd/m²
Sunlight readable
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Max Allocated RAM Size
1792 MB
Camera
Yes - 720p (front)
Resolution
8 Megapixel (rear), 1.3 Megapixel (front)
Camera Features
Autofocus, LED flash
Sound
Speaker, microphone
High Definition Audio
Communications
Wireless
Bluetooth Class
Class 1
Wireless Controller
Intel Dual Band Wireless-AC 7265
Lithium Ion
4400 mAh
Run Time
Up to 14 hours
AC Adapter
Input
Connections & Expansion
Interfaces Details
Dock , HDMI , Headphone output , USB 3.0 , Aerial
Dockable
Security
System password, water-resistant, dust-resistant
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
IEC 60529 IP65, MIL-STD 810G, IP65, IP5X, IP6X
1.1 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
