The LFB70 Series of professional Full HD displays incorporate intuitive touch screen technology, fully interactive whiteboard functionality, and the very latest in wireless connectivity to allow you and your colleagues to work more closely as a team. These displays are loaded with the next-generation technology you need to be more productive, more efficient, and to achieve better quality results.
Simple touch control
Progress smoothly through your presentation using familiar touch screen gestures to turn pages, zoom in and out content, and navigate through multimedia functions without need of a remote control. Whether using a fingertip to cue content for a presentation, or the stylus pen to jot down notes for the group, you'll be delighted at how this user-friendly touch interface makes complex tasks simple. -
Work together on screen
Built-in whiteboard software lets you turn on the display and start work right away - no need to connect a PC. Up to four people can write at a time, and you can save your pages and email them directly to anyone who missed the meeting, notes can be made on almost anything, from video and photos to PowerPoint and PDF documents, and then saved as an image file - simply brilliant for the office or classroom. -
More productive remote meetings
With vibrant Full HD resolution and a wide display area, remote video conference participants seem like they're in the room with you. Team members in remote locations can write detailed notes onto shared documents and solve problems in real time, just as they would when working together in the office. There powerful web and video conferencing capabilities reduce the need for travel, saving your organization time and money. -
Quick-start whiteboard
Start working on the built-in whiteboard instantly - just switch on the display. You can draw straight or freehand lines, and change line thickness, color, and background using the tool palette. To switch input sources, picture settings, and volume, swipe the edge of the screen to display the main menu - no remote control necessary. -
Easy and intuitive operation
Four-point multi-touch functionality makes it easy to resize and move graphics around on your documents. The included Stylus Pen and Eraser accessory is a convenient way to write large amounts of text. So simple to use, even for children and less technically experienced presenters. -
Write and draw on media from external devices
You can write on almost any media you like, including video and still images. Swipe to bring up the main menu, display content from your external device, and start making notes. These dynamic multi-media capabilities make it easy for teams to share information and contribute ideas.
- Panasonic TH-80LFB70E LFB70 - 80" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 80"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- VA
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Input lock, button lock, remote control user level
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, software kit, 2 AA batteries, eraser, stylus stand, 4 pen styluses
- Voltage
- AC 230V (50/60 Hz)
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 186.8 cm x 10.4 cm x 109.3 cm
- 84 kg
- Product Type
- 350 Watt
- Diagonal Class
- 80"
- Commercial Use
- Combined With
- Touchscreen
- Series
- LFB70
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Landscape mode, 1:1 Pixel Mode
- Dimensions
- Without stand
- 186.8 cm
- 10.4 cm
- 109.3 cm
- 84 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- VA
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare
- Image Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Widescreen Modes
- Zoom
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 4 ms
- Backlight Life
- 50,000 hour(s)
- Infrared multitouch technology, Input Search Function
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050
Media Player
- Supported Video Formats
- MPEG-4, WMV, AVI, MOV
- Supported Pictures Formats
- BMP, JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a
- Encryption
- 128-bit WEP, 64-bit WEP, WPA-PSK (TKIP), WPA2, WPA2-PSK (AES)
- Supported Consumer Electronics Control (CEC)
- PJ Link
- Connector Type
- USB - side , USB - side , Composite video input - rear , Component video input - rear , VGA output - rear , VGA input - rear , Serial - rear , DVI-D input - rear , 2 x audio line-in - rear , Speakers output - rear , 2 x HDMI - rear , LAN - rear
- Software kit, 2 AA batteries, eraser, stylus stand, 4 pen styluses
- Cables Included
- USB cable - 2 m
- GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- No signal power off
- Width (Shipping)
- 206.9 cm
- Depth (Shipping)
- 40 cm
- Height (Shipping)
- 131.5 cm
- Weight (Shipping)
- 103 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
