Product
Panasonic TH-70LF50ER 70" Full HD 1920x1080 HDMI LED Display
Quicklinx: CBYHWS00 Mfr#: TH-70LF50ER
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
Hurry, only 1 left in stock!
£4,376.47 ex VAT
£5,251.76 inc VAT
High 700-cd/m2 brightness and 5,000:1 contrast ensure excellent, eye-catching visibility even in large public spaces. This greatly increases the promotional value for signage use. The fan-less design prevents malfunctions otherwise caused by dust particles brought in by the fan. This enables safe installation in crowded areas.
  • Large-screen, high-brightness display capable of displaying clear images even in bright places
  • Fan-less design
  • 24/7 operation
    The tough design makes the display panel suitable for use as signage that operates all day and night in places such as restaurants, shopping malls and transportation facilities.
  • Edge light system used for backlighting
    The edge light system requires a small number of LED units because the lights are installed only on the edges of the LCD panel. This saves energy. The display unit can also be made thin and light.
  • Built-in brightness sensor
    A built-in ambient light sensor detects ambient light and controls brightness. Low power consumption is achieved by controlling the brightness of the backlight.
  • A slim design that fits almost any installation location
    The display can be installed in a permanent hanging position using eyebolts.
Panasonic TH-70LF50ER 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Wall Components Qty
25
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
260 Watt
160.4 cm x 8.9 cm x 93.1 cm
47 kg
260 Watt
Diagonal Class
70"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode, 1:1 Pixel Mode, Seam Hides Video Mode
25
Dimensions
Without stand
160.4 cm
8.9 cm
93.1 cm
47 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Total Pixels
2,073,600
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Certified for 24/7 Continuous Operation, Automatic Picture Positioning, Input Search Function, Function Slot 2.0
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Remote Control
Standard remote
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Composite video input , 2 x audio line-in , HDMI input , Component video / RGB input , DVI-D input , VGA input , Audio line-in , DVI-D output , Serial input , Serial output , Network , Audio line-out
2 AA batteries
GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
175 cm
Depth (Shipping)
34.9 cm
Height (Shipping)
104.7 cm
Weight (Shipping)
56 kg
20 - 80% (non-condensing)
Video Interface: Composite
Video Interface: HDMI
Brand: Panasonic
Price Range Ex VAT: 1500+
