This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF8 series is less than half the 16 mm (0.7") bezel width of the LF6 series. And the slim design makes the depth only 57 mm (2.3"). Since the LF8 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact.
Performance with 500 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports.
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities.
Featuring industrial durability and reliability, as well as a stylish appearance
This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF8 series is less than half the 16 mm (0.7") bezel width of the LF6 series. And the slim design makes the depth only 57 mm (2.3"). Since the LF8 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact. -
High brightness for displaying easy-to-see content in bright places
Performance with 500 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports. -
The IPS panel has a wide viewing angle and minimal color fluctuations
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities. -
USB media player for simple signage use without an STB
The LF8 series features a USB media player. Signage operation is possible by simply inputting the desired content via USB, eliminating the need for a set-top box. Both videos and still images can be displayed, so a wide variety of original signage content can be used. -
Easy display of images optimized for the display content and viewing environment
Conventional display panels are preset with display modes such as Standard and Dynamic. The LF8 series comes with an extensive display menu to let you select the most suitable mode for the content to be displayed and the viewing environment. You can select the best mode for the video source and the place of display.
- Panasonic TH-55LF8W LF8 - 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Input lock, button lock, remote control user level
- Settings Cloning Capability
- Picture Enhancements
- Colour Enhancement, Colour Refiner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries, 3 clampers
- Voltage
- AC 230V (50/60 Hz)
- 185 Watt
- Power Consumption (On mode)
- 140 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 122.9 cm x 7.2 cm x 69.9 cm
- 24.7 kg
- Product Type
- 185 Watt
- 140 W
- Diagonal Class
- 55"
- Commercial Use
- Series
- LF8
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, 1:1 Pixel Mode, Dynamic Picture Mode
- Design
- Narrow Bezel Design
- Dimensions
- Without stand
- 122.9 cm
- 7.2 cm
- 69.9 cm
- 24.7 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 500 cd/m²
- Widescreen Modes
- Zoom
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Backlight Life
- 60,000 hour(s)
- Certified for 24/7 Continuous Operation, MPEG Noise Reduction, Input Search Function, Fail Back
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 852 x 480, 1152 x 870, 1360 x 768, 640 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050, 1600 x 900
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Fast Ethernet
- Supported Consumer Electronics Control (CEC)
- PJ Link
- Connector Type
- Serial output , Serial input , Infrared input , Infrared output , VGA input , 2 x audio line-in , Composite video / component video input , Audio line-out , LAN , 2 x HDMI input , DVI-D input , DVI-D output , USB 2.0
- 2 AAA batteries, 3 clampers
- IEC 60950-1, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A, AS/NZS CISPR 22:2009
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Power on delay
- Width (Shipping)
- 144.4 cm
- Depth (Shipping)
- 22.3 cm
- Height (Shipping)
- 92.2 cm
- Weight (Shipping)
- 32 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
