Panasonic TH-32EF1E 32" Full HD LCD Large Format Display
Quicklinx: CBY6WS00 Mfr#: TH-32EF1E
TV Tuner Presence: No
Video Interface: Composite, HDMI
  • 1080p (Full HD)
15 in stock
£341.18 ex VAT
£409.41 inc VAT
The TH-32EF1 is often used vertically for menu boards and town guide displays, and can be mounted in landscape and portrait. This provides information that is easy to see even in relatively high places inside the store, and increases mounting possibilities. The narrow frame and slim design draw attention to the image. And the flat-panel form does not feel oppressive when mounted on the wall. The high-visibility IPS panel makes images easier to see and boosts the signage effect.
  • Slim design for any interior design scheme
  • Built-in USB media player
    A USB media player is built right into the display, so you simply insert a USB memory stick for automatic video and still-image playback. Signage can be easily created without requiring a set-top box or a PC. You can also compile scenario files to designate the playback order and time.
  • Quick and easy signage
    The USB media player features synchronized playback on multiple displays. The content can be rewritten via a LAN network, so you can even mount the displays at a distance.
  • Cloning function
    When installing multiple displays, the Cloning function lets you use USB memory to copy the settings of a master display, thus greatly shortening the setup time.
  • Versatile input terminals and speakers
    The TH-32EF1 comes with a host of input terminals. In addition to providing versatile video displays, these terminals enable external control and simple video wall setup.
  • Choose the installation to match your application
Panasonic TH-32EF1E 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 1080/24PsF
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
65 Watt
Power Consumption (On mode)
55 W
Power Consumption Stand by
0.5 Watt
72.7 cm x 6.4 cm x 42.6 cm
5.3 kg
65 Watt
55 W
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode
Dimensions
Without stand
72.7 cm
6.4 cm
42.6 cm
5.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
50,000 hour(s)
Commercial Features
Input Search Function, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
VESA Mounting Interface
100 x 100 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 720 x 480, 1280 x 720, 852 x 480, 1152 x 870, 1360 x 768, 640 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050, 1600 x 900, 720 x 576
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
LAN
LAN Protocol
Fast Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Composite video input - rear , 2 x HDMI input - rear , DVI-D input - rear , VGA input - rear , Serial input , Network - rear , Infrared input , Infrared output , Audio line-in - rear , Audio line-out - rear , USB - rear
2 AAA batteries, 3 clampers
IEC 60065, EN 55020, BEAB, EN55013, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A, EN 60065:2014, EN 55032:2012+AC:2013 Class A
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Width (Shipping)
81.8 cm
Depth (Shipping)
13.9 cm
Height (Shipping)
54.7 cm
Weight (Shipping)
8 kg
20 - 80% (non-condensing)
Video Interface: HDMI
Brand: Panasonic
Price Range Ex VAT: 300 - 500
