When the area around the other party is noisy and it is difficult to hear, you can reduce the surrounding noise to make the speaker's voice easier to hear just by pressing the dedicated button.
Simply attach the key finder/key detector to items that you often misplace, and use the handset to find them quickly and easily. You can see roughly how close you are to your lost item on the LCD screen, and both the handset and key finder/key detector beep when being searched for, making them easy to find. You can add up to four key finders/key detectors.
Noise reduction reduce the background noise of the other party
When the area around the other party is noisy and it is difficult to hear, you can reduce the surrounding noise to make the speaker's voice easier to hear just by pressing the dedicated button. -
Incoming call barring stops unwanted junk calls
You can block annoying calls from unwanted numbers. Numbers on your call block list will be blocked (the unit emits no sound to the caller, and disconnects the call) if they call you. -
Shared phonebook
The phonebook can be automatically shared between handsets without having to copy it, so you can use it in the kitchen, the living room, etc. Any handset registered to the base unit can use the shared phonebook. -
Smart function key
The smart function key flashes according to the situation. By pressing this key while it is flashing, you can play an answering machine message or respond to a call. -
Key finder/key detector compatible
- Panasonic KX-TG6812 - cordless phone with caller ID + additional handset
- Product Type
- Cordless phone with caller ID + additional handset
- Total Number of Wireless Handsets
- 2
- Cordless Phone Standard
- DECT\GAP
- Speakerphone
- Caller ID
- Call Services
- Caller ID
- Display
- LCD display - monochrome - Yes
- Body Colour
- Black
- Product Type
- Cordless phone
- Additional Handsets Qty
- 1
- 2
- Body Colour
- Black
Phone Features
- DECT\GAP
- Call Services
- Caller ID
- Caller ID Type
- Caller ID
- Max Handsets Supported
- 6
- Multi-Handset Configuration
- Phonebook transfer
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Menu Operation
- Ring Tones
- 40
- Polyphonic Ringer
- Handset Locator
- Indicators
- Visual ringer light
- Lighted Keypad
- Additional Functions
- Alarm, call barring, built-in clock with snooze function, phonebook transfer
- Additional Features
- Noise reduction, key lock, eco mode, night mode
Phone Memory
- Phone Directory Capacity
- 120 names & numbers
- Dialed Calls Memory
- 10
- Caller ID Memory
- 50 names & numbers
Display
- Display Location
- Handset
- Diagonal Size
- 1.8"
- Display Resolution
- 103 x 65 pixels
- Backlit
- Included Accessories
- Power adapter, phone charging stand
- Battery
- 2 x battery - AAA type
- Technology
- Rechargeable - Nickel Metal Hydride
- Talk Time
- Up to 900 min
- Standby Time
- Up to 170 h
- Recharge Time
- 7 hour(s)
Dimensions & Weight (Base)
- 10.7 cm
- 8.6 cm
- 7.7 cm
- 98 g
Dimensions & Weight (Handset)
- 4.8 cm
- 2.9 cm
- 16.4 cm
- 129 g
