Panasonic PT VZ575NAJ WUXGA LCD 4500 Lumens Projector
Quicklinx: BJSXWS00 Mfr#: PT-VZ575NAJ
Panasonic PT-VZ575N are the first portable LCD projectors that feature WUXGA (1920 x 1200 pixel) resolution, bringing native Full HD video to big screens in small spaces. Images are pin-sharp, liquid-smooth, and loaded with detail for an immersive viewing experience.
  • Exceptionally bright and clear image quality
    The compact and lightweight PT-VZ570 Series outputs up to an impressive 5,500 lm 1. High brightness brings colors to life, adding punch and realism to presentations in well-lit rooms.
  • Whisper-quiet operation
    The PT-VZ570 Series produces a barely audible 29 dB 2 in Eco Mode. Your audience won't have to strain to hear in quiet scenes or be distracted by unwanted noise.
  • High 5,000:1 contrast ratio
    Panasonic's winning formula for imaging brilliance is completed by a high 5,000:1 contrast ratio. Expect deep blacks, pure highlights, and crisp, easy to read text and graphics.
  • Daylight view basic suits ambient conditions
    Daylight View Basic prevents the picture from washing out in bright rooms by sensing ambient light levels and adjusting the picture accordingly. Halftone color and brightness are automatically optimized to make images sharper and brighter in any environment.
  • Lamp and filter replacement extended to 7,000 hours
    The PT-VZ570 Series halves the usual cost of projector maintenance by extending lamp and filter operational life to an impressive 7,000 hours 3, almost double that of the conventional models. When maintenance is eventually due, you can replace both the lamp and filter at the same time, even with the projector mounted on the ceiling.
  • Distortion-free vertical lens shift
    The PT-VZ570 Series features a Vertical Lens Shift function that allows you to move the image up or down without distorting the picture. This is useful for quick image corrections in portable applications.
  • Horizontal, vertical, and corner keystone correction
    Horizontal, vertical, and corner keystone correction adjusts the image shape to perfection when projecting off-axis or from an unusual angle. Should the vertical projection angle be altered during operation, Real-time Keystone Correction senses the change and makes any necessary corrections for optimal viewing.
  • Compatible with leading control systems
    The PT-VZ570 Series plugs into existing projection networks controlled by Crestron Connected, PJLink Class 1, and AMX software. Multi-projector and monitoring software enables control of multiple projectors from a PC.
  • Project onto curved surfaces
    Curved Screen Correction, meanwhile, allows you to project natural, distortion-free images onto curved or cylindrical surfaces.
  • More input terminals means more versatility
    Whether you're planning to install your PT-VZ570 Series projector on the ceiling or take it with you to a meeting, a generous selection of input terminals are included to connect a variety of source devices. These include two HDMI terminals and two RGB D-Sub ports for PC.
Panasonic PT-VZ575NAJ - LCD projector - 802.11n wireless / LAN
LCD projector - 1080p
Built-in Devices
Speaker
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Vertical
Bulb type
UHM 270 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11n wireless / LAN
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
Speakers
Speaker(s) - integrated
38.9 cm x 33.2 cm x 12.5 cm
4.9 kg
Built-in Devices
Speaker
802.11a/b/g/n, Ethernet
Projector
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.1 - 1.8:1
Uniformity
85 %
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
2,304,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
100 Hz x 91 kHz
Bulb type
UHM 270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Deep Color, Split Screen, PJlink, AMX Device Discovery, Direct Power Off, Crestron e-Control, Colourboard Mode, Dynamic Mode, Digital Link, USB Viewer, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6-2.12
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-25 / +25
Horizontal Keystone Correction
-30 / +30
Vertical
Vertical Lens Shift
44%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel - 4 cm
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input / RGB output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
2 x AAA batteries, wireless remote control, cable holder
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
Power Source
AC
Nominal Voltage
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software
38.9 cm
33.2 cm
12.5 cm
4.9 kg
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
