Panasonic PT-VZ575N are the first portable LCD projectors that feature WUXGA (1920 x 1200 pixel) resolution, bringing native Full HD video to big screens in small spaces. Images are pin-sharp, liquid-smooth, and loaded with detail for an immersive viewing experience.
Exceptionally bright and clear image quality
The compact and lightweight PT-VZ570 Series outputs up to an impressive 5,500 lm 1. High brightness brings colors to life, adding punch and realism to presentations in well-lit rooms. -
Whisper-quiet operation
The PT-VZ570 Series produces a barely audible 29 dB 2 in Eco Mode. Your audience won't have to strain to hear in quiet scenes or be distracted by unwanted noise. -
High 5,000:1 contrast ratio
Panasonic's winning formula for imaging brilliance is completed by a high 5,000:1 contrast ratio. Expect deep blacks, pure highlights, and crisp, easy to read text and graphics. -
Daylight view basic suits ambient conditions
Daylight View Basic prevents the picture from washing out in bright rooms by sensing ambient light levels and adjusting the picture accordingly. Halftone color and brightness are automatically optimized to make images sharper and brighter in any environment. -
Lamp and filter replacement extended to 7,000 hours
The PT-VZ570 Series halves the usual cost of projector maintenance by extending lamp and filter operational life to an impressive 7,000 hours 3, almost double that of the conventional models. When maintenance is eventually due, you can replace both the lamp and filter at the same time, even with the projector mounted on the ceiling. -
Distortion-free vertical lens shift
The PT-VZ570 Series features a Vertical Lens Shift function that allows you to move the image up or down without distorting the picture. This is useful for quick image corrections in portable applications. -
Horizontal, vertical, and corner keystone correction
Horizontal, vertical, and corner keystone correction adjusts the image shape to perfection when projecting off-axis or from an unusual angle. Should the vertical projection angle be altered during operation, Real-time Keystone Correction senses the change and makes any necessary corrections for optimal viewing. -
Compatible with leading control systems
The PT-VZ570 Series plugs into existing projection networks controlled by Crestron Connected, PJLink Class 1, and AMX software. Multi-projector and monitoring software enables control of multiple projectors from a PC. -
Project onto curved surfaces
Curved Screen Correction, meanwhile, allows you to project natural, distortion-free images onto curved or cylindrical surfaces. -
More input terminals means more versatility
Whether you're planning to install your PT-VZ570 Series projector on the ceiling or take it with you to a meeting, a generous selection of input terminals are included to connect a variety of source devices. These include two HDMI terminals and two RGB D-Sub ports for PC.
- Panasonic PT-VZ575NAJ - LCD projector - 802.11n wireless / LAN
- LCD projector - 1080p
- Built-in Devices
- Speaker
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 5000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Vertical
- Bulb type
- UHM 270 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11n wireless / LAN
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 38.9 cm x 33.2 cm x 12.5 cm
- 4.9 kg
- Built-in Devices
- Speaker
- Networking
- 802.11a/b/g/n, Ethernet
Projector
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 5000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.1 - 1.8:1
- Uniformity
- 85 %
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Video Bandwidth
- 162 MHz
- Display Format
- 2,304,000 pixels (1920 x 1200) x 3
- Max Sync Rate (V x H)
- 100 Hz x 91 kHz
- Bulb type
- UHM 270 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Deep Color, Split Screen, PJlink, AMX Device Discovery, Direct Power Off, Crestron e-Control, Colourboard Mode, Dynamic Mode, Digital Link, USB Viewer, Eco Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6-2.12
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -25 / +25
- Horizontal Keystone Correction
- -30 / +30
- Vertical
- Vertical Lens Shift
- 44%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a, IEEE 802.11n, Miracast
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel - 4 cm
- 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input / RGB output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- Included Accessories
- 2 x AAA batteries, wireless remote control, cable holder
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- Software Included
- Logo Transfer Software, Multi Projector Monitoring & Control Software
- 38.9 cm
- 33.2 cm
- 12.5 cm
- 4.9 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
