The PT-EX16KE LCD projector features 16,000 lumens of brightness XGA resolution, is added to the large venue lineup for houses of worship, mid sized rental and staging and customers seeking large venue projection images for moderate use. The product is equipped with a quad lamp technology and encased in a ruggedized shell for high reliability and durability. In addition, its unique light filtering technology recognizes high color purity to deliver vivid images.
- Panasonic PT-EX16KE - LCD projector
- LCD projector
- Localisation
- Asia, Middle East, Africa, Europe, Oceania
- Brightness
- 16000 lumens
- Contrast Ratio
- 2500:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 4 x 380 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 1125/60i, 1125/50i, 1035/60i
- Video Output
- RGB
- Power
- AC 230V (50/60 Hz)
- 1850 Watt
- 65 cm x 81.5 cm x 34.9 cm
- 46.5 kg
- LCD projector
- Localisation
Projector
- Brightness
- 16000 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 102 cm - 1524 cm
- Uniformity
- 90 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Video Bandwidth
- 162 MHz
- Display Format
- 2,359,296 pixels (1024 x 768)
- Max Sync Rate (V x H)
- 85 Hz x 80 kHz
- Bulb type
- 4 x 380 Watt
- Bulb life cycle
- Edge blending, High-bandwidth Digital Content Protection System (HDCP), carrying handle, PJlink
Lens
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical Keystone Correction
- -40 / +40
- Horizontal Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, S-Video, DVI
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Input Device
- External
- 1 x DVI-D input - 24+1 pin digital DVI , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite / component video / RGB input - BNC x 5 , 1 x USB - 4 pin USB Type B , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232C output - 9 pin D-Sub (DB-9)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- RoHS
- Voltage Required
- 1850 Watt
- Power Consumption Operational (Standby)
- 18 Watt
- Software Included
- Real Color Manager Pro, Logo Transfer Software, Multi Projector Monitoring & Control Software
- 65 cm
- 81.5 cm
- 34.9 cm
- 46.5 kg
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 51 dB
- Sound Emission (Economic Mode)
- 48 dB
