Your basket is empty
Panasonic Pan Tilt Cradle for Camcorders
Quicklinx: 9V7GWS00 Mfr#: VW-CTR1EB-K
£153.08 ex VAT
£183.69 inc VAT
Connect a compatible Panasonic Camcorder to this remote pan and tilt cradle and your camcorder becomes an active party recording device that never misses the action. Its also a perfect solution for home and baby monitoring when combined with the cameras Wi-Fi remote control function.
Make the camera rotate automatically. The motion sensor and face recognition function allow you to automatically capture video of everyone's faces at parties and other gatherings. The motion sensor even lets you use the camera to watch over pets when you are not home. You can operate directly from the camcorder, or use remote control with the Panasonic Image App.
Panasonic VW-CTR1 - video tracking stand
Accessory Type
Video tracking stand
7.2 cm
Diameter
12.96 cm
340 g
Panasonic HC-V230M, HC-V250, HC-V360M, HC-V360MS, HC-V480M, HC-V480MS, HC-V550, HC-V550CT, HC-V550M, HC-V750, HC-V750M, HC-V757, HC-V770, HC-V777, HC-VX870, HC-VX878, HC-VX981, HC-VX985M, HC-VX989, HC-W570, HC-W570M, HC-W580M, HC-W850, HC-W870M, HC-WX990M, HC-WX995M, HC-WXF990M, HC-WXF991, NV-GS5K
Accessory Type
7.2 cm
Diameter
12.96 cm
340 g
Accessories
Intended for
Camcorder
Quick-release system, remote control via mobile devices
Brand: Panasonic
Price Range Ex VAT: 150 - 300
