Panasonic Lumix DMC-TZ70 12.1MP 30x Zoom Superzoom Compact - Black
Quicklinx: D9JFWS00 Mfr#: DMC-TZ70EB-K
£188.89 ex VAT
£226.66 inc VAT
Photographing epic landscapes from afar or zooming up close to pick out the finest details, the LUMIX TZ70 is designed to suit both low and bright light image capturing. It is the perfect camera to accompany you when discovering the world. LUMIX TZ70 is the ultimate camera for every destination. Every feature is built for the traveler in you. From architectural patterns to subtle color gradations, the TZ70 lets you photograph with ease, under any light condition, its compact size also makes it ideal for slipping into a pocket or a bag for easy access. Wherever you're traveling, make sure the LUMIX TZ70 is there to capture every detail.
  • Get closer with the 30x zoom LEICA lens
    The LUMIX TZ70 brings you right up against the action. The 24mm Leica DC Vaho-Elmar lens has a 30x optical zoom so you will always have an intimate view, and captured picture, of what piques your interest.
  • Stunning in low light
    Low light conditions can be a challenge but with the LUMIX TZ70's large pixel-sized High Sensitivity MOS sensor and Venus Engine image processor, you can take stunning pictures even in dimly lit environments. Pictures taken in low light will contain clearer details and less image noise.
  • See clearer with the live view finder
    Wherever your travels take you and whatever the light conditions are, the Live View Finder is an invaluable gem. Perfect for framing the image when light conditions make it difficult to use the LED screen, the eye sensor automatically detects your viewing preference and switches image display to the Live View Finder.
  • Control Ring
    The Control Ring now provides smoother manual control of the exposure, zoom, and focus; leaving you free to concentrate on shutter operation with your other hand. Its intuitive design, precise focusing plus smooth and silent operation gives you total control over every picture and video taken.
  • Manual focus peaking
    Compose your perfect shot with precision. The manual control ring enables smooth operation of the Focus Peaking function, it indicates the area of focus and depth of field so you can concentrate on your composition.
  • Experience the action - high speed response
    Take perfect pictures or videos, of even the fastest moving action with the LUMIX TZ70's Light Speed Auto Focus and 10fps High Speed Burst Shooting. No matter how fast your subject is, the camera shoots just as fast, capturing perfectly focused images every time.
  • RAW format recording
    Capture more details when you shoot in RAW format. The image data retains the original color and light information captured by the sensor, with only minimal processing. Now you can edit these high quality images directly and be amazed by the results.
  • Reveal more details with macro shots
    Satisfy your desire for intricate details as they are brought to clarity with the 3cm macro shots. See more up close with the LUMIX T270.
  • Time-lapse recording
    Be in awe of the natural drama such as a rising sun over an epic horizon, with your time-lapse recording. Simply input the start time, shooting interval and the number of images needed and the camera takes care of the rest. The LUMIX TZ70 even records your time-lapse moments in amazing Full HD quality.
  • High speed video
    The LUMIX TZ70 now records with 100fps in High Definition resolution and 200fps in VGA. This lets you keep up with any fast moving action so you can later enjoy in crystal clear slow motion.
  • Showtime in Full HD
    The LUMIX TZ70 lets you record videos in Full HD quality, in AVCHD or MP4 format. This results in stunningly smooth high resolution playback when you watch your captured videos on computers or large screen TVs.
Panasonic Lumix DMC-TZ70 - digital camera - Leica
Digital camera - compact
Lens Included
Leica
Memory Card Slot
SD card
Image Processor
Venus Engine
Sensors
Digital level metre
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
12.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
Focus Adjustment
Automatic, manual
Min Focus Distance
50 cm
Digital Zoom
4x
Image Stabiliser
Optical (HYBRID O.I.S. +)
Camera Flash
Built-in flash
Viewfinder
Built-in - 0.2" - colour - electronic
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery - 1250 mAh (included)
Composite video/audio, HDMI, USB 2.0
11.07 cm x 3.44 cm x 6.46 cm
217 g
Lens Included
Leica
Enclosure Colour
Sensor Resolution
12.1 Megapixel
Optical Sensor Type
Total Pixels
12,800,000 pixels
Effective Sensor Resolution
12,100,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
30x
Digital Zoom
4x
Image Processor
Venus Engine
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Sensors
Digital level metre
Print Standard
DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
23
AE/AF Control
Face-priority AF, Subject-tracking AF, Touch Area AF
Face Detection
Face Detection AF/AE
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, MPO
1920 x 1080
Auto Focus Features
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, hi-speed shutter, night portrait, PET, scenery, food, 3D image, night scene, sports mode, sunset, behind glass, high sensitivity, starry sky, soft skin, baby1, baby2, handheld night shot, Dynamic Range (HDR)
Special Effects
Sepia, soft focus, miniature, Cross Process, Retro, Expressive, high dynamic, Toy effect, Star Filter, Impressive Art, One Point Colour, Dynamic Monochrome, Old Days, Bright tones, Dark tones
Retouch
Creative Retouch
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, daylight, shade
Max Shutter Speed
1/2000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
Lens System
Leica zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
Focal Length Equivalent to 35mm Camera
24 - 720mm
Focus Adjustment
Automatic, manual
Min Focus Distance
50 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
9 groups / 12 elements
Built-in lens shield, ED glass, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.6 m - 6.4 m: ISO auto (wide lens) , 2 m - 3.3 m: ISO auto (tele lens)
Additional Features
Continuous Shooting Speed
3 frames per second, 10 frames per second, 6 frames per second, 40 frames per second (5MP), 60 frames per second (2.5MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, RGB primary colour filter, date/time stamp, histogram display, AE lock, AF lock, in-camera red-eye removal, cropping an image, resizing an image, in-camera film editing, USB charging, Intelligent Auto Plus (iA+), high-speed recording, Time-Lapse recording, Light Speed AF, Level Shot Function
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.2"
Viewfinder Resolution
1,166,000 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
2.59x
Display
3" LCD display
Display Format
1,040,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
Software
Adobe Reader, Loilo LoiLoScope (Trial), Panasonic PHOTOfunSTUDIO 9.6 Premium Edition
Hand strap, power adapter, USB cable
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 300 shots
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
JPEG 4000 x 3000 , JPEG 3264 x 2448 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 4000 x 2672 , JPEG 3264 x 2176 , JPEG 2048 x 1360 , JPEG 640 x 424 , JPEG 4000 x 2248 , JPEG 3840 x 2160 , JPEG 2560 x 1440 , JPEG 1920 x 1080 , JPEG 640 x 360 , JPEG 2992 x 2992 , JPEG 2448 x 2448 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1280 x 720 - 50 fps - 17Mbps , H.264 - 1920 x 1080 - 25 fps - 20Mbps , H.264 - 1280 x 720 - 25 fps - 10Mbps , H.264 - 640 x 480 - 25 fps - 4Mbps , H.264 - 1280 x 720 - 100 fps , H.264 - 640 x 480 - 200 fps
11.07 cm
3.44 cm
6.46 cm
217 g
