In addition to the predecessor's quad-proof durability, the DMC-FT5 comprehends pressure resistance. Take out the camera to fishing or camping in the springtime, to diving, snorkeling, surfing in summer, or mountain climbing in autumn and to skiing or snowboarding in winter - the DMC-FT5 is an all-year-round active field player to record stunning memories in beautiful photo and video. The DMC-FT5 features pressure resistance of 100 kgf thanks to the reinforced rib structure of its internal design. You can safely put it in the pocket or backpack with ease.
5 proof protections - ruggedly designed body for powerful outdoor use
The ruggedly designed body is waterproof to 13 m, shockproof to 2.0 m, freezeproof to -10 degrees C, dustproof and pressure resistant to 100 kgf. It also features anti-fog glass. -
60p/50p Full HD video to record subjects with fast motion or fine details clearly
The 60p/50p Full HD video recording capability makes this camera twice as attractive. It creates intricate detail and silky smooth motion. -
Ultimate toughness
In addition to the predecessor's quad-proof durability, the DMC-FT5 comprehends pressure resistance. Take out the camera to fishing or camping in the springtime, to diving, snorkeling, surfing in summer, or mountain climbing in autumn and to skiing or snowboarding in winter - the DMC-TS5 (FT5) is an all-year-round active field player to record stunning memories in beautiful photo and video. -
LEICA DC lens with Folded Optics technology
The DMC-FT5 features a high-quality LEICA DC lens with 4.6x optical zoom from 28 mm wide-angle. The folded optics of shaft guide method is adopted to secure the toughness of the lens unit. Passing the Leica's stringent standards, this lens delivers exceptional optical performance to the edges. -
28 mm wide-angle lens
The 28 mm wide-angle lens lets you easily capture large groups of people indoors or expansive architectural structures and scenes with dynamic width and rich perspective, even from short distances. -
Power O. I. S. (Optical Image Stabilizer)
The power O. I. S. (Optical Image Stabilizer) suppresses the low-frequency vibration hand-shake component, which is physically generated when pressing the shutter button or when shooting at night with a slow shutter speed. -
16.1-megapixel MOS sensor
The 16.1-megapixel high sensitivity MOS sensor realizes both high quality image recording and high speed signal processing. In addition, the Wavelet NR system 1 in the Venus Engine enables deliberate noise reduction process without missing low-frequency noise by enlarging its detection area by approximately 64 x 2. It results in the high sensitivity image recording even at ISO3200. -
Venus Engine
The DMC-FT5's Venus Engine processes large amount of progressive Full HD data at high speed. At the same time, the multi-task image-processing engine, the Venus Engine realizes a super-fast response time. -
10 fps with 16.1-megapixel full resolution
The developed MOS sensor lets the DMC-FT5 shoot 10 fps in 16.1-megapixel full resolution with mechanical shutter and 5 fps with continuous AF. You can take a series of shots, then choose the ones you like the best and delete the rest. -
Light speed AF
The light speed AF helps to catch even the most fleeting photo opportunities. You can quickly focus on moving subjects, such as when you're shooting sports scenes or animals. -
1920 x 1080 60p/50p Full HD video record
The DMC-FT5 can record full HD 1,920 x 1,080 videos in AVCHD progressive format. Upgrading 60p/50p Full HD recording capability, subjects with fast motion or fine details are reproduced clearly. -
Stereo microphone
The videos also come with the high-quality stereo sound of Dolby Digital, to offer highly realistic sound to the motion images. The stereo microphone comes with zoom noise reduction system, and the auto wind cut function blocks out most of the noise from background wind. -
Torch light
The DMC-FT5 features a torch light that records beautiful videos even in dusky underwater environments or at a nighttime camp. It is also possible to turn only light on to light up subject even while camera function is not activated. -
Advanced underwater mode
The red color reproduction of advanced underwater mode compensates for the red color which is easily lost in underwater shooting to look underwater picture more natural. Sports, Snow and beach & snorkeling mode can also be selected easily and quickly from the menu. -
Manual exposure
The DMC-FT5 provides easy-to-use manual controls. You can set the aperture to control the depth of field, and adjust the shutter speed to freeze moving subjects or create a motion blur that exaggerates the feeling of movement. -
iA (Intelligent Auto) mode
In the iA (Intelligent Auto) mode, the camera does all the work, leaving you free to compose your shot and capture the moment. You just press, aim and shoot. The detection and correction functions go to work to give you beautiful photos and videos with maximum ease.
- Panasonic Lumix DMC-FT5 - digital camera - Leica
- Product Type
- Digital camera - compact
- Lens Included
- Leica
- Memory Card Slot
- SD card
- Image Processor
- Venus Engine
- Sensors
- Barometer, magnetometer, altimeter
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 16.1 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 4.6x zoom - 4.9 - 22.8 mm - f/3.3-5.9
- Focus Adjustment
- Automatic
- Min Focus Distance
- 30 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (POWER O.I.S.)
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery - 1250 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Orange
- 10.92 cm x 2.89 cm x 6.74 cm
- 188 g
- Product Type
- Lens Included
- Leica
- Built-in Light
- LED lights
- Enclosure Colour
- Orange
- Sensor Resolution
- 16.1 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 17,500,000 pixels
- Effective Sensor Resolution
- 16,100,000 pixels
- Optical Sensor Size
- 1/2.33"
- ISO (Max)
- 6400
- Optical Zoom
- 4.6x
- Digital Zoom
- 4x
- Image Processor
- Venus Engine
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Navigation
- GPS receiver, GPS/GLONASS receiver
- Sensors
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 23
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Face Recognition
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG, MPO
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO auto (1600-6400)
- Exposure Metering
- Multi-segment
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Portrait mode, night portrait, PET, scenery, food, night scene, sunset, behind glass, high sensitivity, starry sky, soft skin, baby1, baby2, handheld night shot, Dynamic Range (HDR)
- Special Effects
- Black & White, Sepia, Vivid, miniature, Cross Process, Retro, Happy, Expressive, high dynamic, High Key, Low Key, Toy effect, Star Filter, Impressive Art, One Point Colour, Dynamic Monochrome
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, daylight, shade
- Max Shutter Speed
- 1/1300 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps
Lens System
- Leica zoom lens - 4.6x zoom - 4.9 - 22.8 mm - f/3.3-5.9
- Focal Length Equivalent to 35mm Camera
- 28 - 128mm
- Focus Adjustment
- Automatic
- 30 cm
- Macro Focus Range
- 5cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 10 elements
- ED glass, aspherical lens, anti-fog coating
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.3 m - 5.6 m: ISO auto (wide lens) , 1 m - 3.1 m: ISO auto (wide lens)
Additional Features
- Continuous Shooting Speed
- 2 frames per second, 5 frames per second, 40 frames per second (5MP), 60 frames per second (2.5MP), 10 frames per second for 7 frames
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Audio recording, built-in speaker, date/time stamp, histogram display, in-camera red-eye removal, cropping an image, resizing an image, Intelligent Scene Selector, in-camera film editing, Intelligent Resolution Technology, face detection, automatic display brightness adjustment, Intelligent Auto (iA), text input to Exif header, Time-Lapse recording, primary colour filter, Intelligent HDR mode, Wi-Fi Direct
Display
- 3" LCD display
- Display Format
- 460,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output
Software
- Software
- Drivers & Utilities, Adobe Reader, Panasonic PHOTOfunSTUDIO 9.1 Premium Edition
- Included Accessories
- Battery charger, hand strap, USB cable
- Protection
- Waterproof, freezeproof, shockproof, dust-resistant
- Underwater Use
- Underwater Depth
- Up to 13 m
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Photo shooting - 370 shots
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2560 x 1920 , JPEG 2560 x 1712 , JPEG 2560 x 1440 , JPEG 2048 x 1536 , JPEG 2048 x 1360 , JPEG 1920 x 1080 , JPEG 1280 x 960 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3456 x 3456 , JPEG 2736 x 2736 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1280 x 720 - 50 fps - 17Mbps , H.264 - 1920 x 1080 - 25 fps - 20Mbps , H.264 - 1280 x 720 - 25 fps - 10Mbps , H.264 - 640 x 480 - 25 fps - 4Mbps
- 10.92 cm
- 2.89 cm
- 6.74 cm
- 188 g
- -10 °C
- 40 °C
