Panasonic Lumix DMC-FT5 16MP 4.6xZoom 3D Camera - Orange
Quicklinx: 9V59WS00 Mfr#: DMC-FT5EB-D
  • SDHC Memory Card
In addition to the predecessor's quad-proof durability, the DMC-FT5 comprehends pressure resistance. Take out the camera to fishing or camping in the springtime, to diving, snorkeling, surfing in summer, or mountain climbing in autumn and to skiing or snowboarding in winter - the DMC-FT5 is an all-year-round active field player to record stunning memories in beautiful photo and video. The DMC-FT5 features pressure resistance of 100 kgf thanks to the reinforced rib structure of its internal design. You can safely put it in the pocket or backpack with ease.
  • 5 proof protections - ruggedly designed body for powerful outdoor use
    The ruggedly designed body is waterproof to 13 m, shockproof to 2.0 m, freezeproof to -10 degrees C, dustproof and pressure resistant to 100 kgf. It also features anti-fog glass.
  • 60p/50p Full HD video to record subjects with fast motion or fine details clearly
    The 60p/50p Full HD video recording capability makes this camera twice as attractive. It creates intricate detail and silky smooth motion.
  • Ultimate toughness
    In addition to the predecessor's quad-proof durability, the DMC-FT5 comprehends pressure resistance. Take out the camera to fishing or camping in the springtime, to diving, snorkeling, surfing in summer, or mountain climbing in autumn and to skiing or snowboarding in winter - the DMC-TS5 (FT5) is an all-year-round active field player to record stunning memories in beautiful photo and video.
  • LEICA DC lens with Folded Optics technology
    The DMC-FT5 features a high-quality LEICA DC lens with 4.6x optical zoom from 28 mm wide-angle. The folded optics of shaft guide method is adopted to secure the toughness of the lens unit. Passing the Leica's stringent standards, this lens delivers exceptional optical performance to the edges.
  • 28 mm wide-angle lens
    The 28 mm wide-angle lens lets you easily capture large groups of people indoors or expansive architectural structures and scenes with dynamic width and rich perspective, even from short distances.
  • Power O. I. S. (Optical Image Stabilizer)
    The power O. I. S. (Optical Image Stabilizer) suppresses the low-frequency vibration hand-shake component, which is physically generated when pressing the shutter button or when shooting at night with a slow shutter speed.
  • 16.1-megapixel MOS sensor
    The 16.1-megapixel high sensitivity MOS sensor realizes both high quality image recording and high speed signal processing. In addition, the Wavelet NR system 1 in the Venus Engine enables deliberate noise reduction process without missing low-frequency noise by enlarging its detection area by approximately 64 x 2. It results in the high sensitivity image recording even at ISO3200.
  • Venus Engine
    The DMC-FT5's Venus Engine processes large amount of progressive Full HD data at high speed. At the same time, the multi-task image-processing engine, the Venus Engine realizes a super-fast response time.
  • 10 fps with 16.1-megapixel full resolution
    The developed MOS sensor lets the DMC-FT5 shoot 10 fps in 16.1-megapixel full resolution with mechanical shutter and 5 fps with continuous AF. You can take a series of shots, then choose the ones you like the best and delete the rest.
  • Light speed AF
    The light speed AF helps to catch even the most fleeting photo opportunities. You can quickly focus on moving subjects, such as when you're shooting sports scenes or animals.
  • 1920 x 1080 60p/50p Full HD video record
    The DMC-FT5 can record full HD 1,920 x 1,080 videos in AVCHD progressive format. Upgrading 60p/50p Full HD recording capability, subjects with fast motion or fine details are reproduced clearly.
  • Stereo microphone
    The videos also come with the high-quality stereo sound of Dolby Digital, to offer highly realistic sound to the motion images. The stereo microphone comes with zoom noise reduction system, and the auto wind cut function blocks out most of the noise from background wind.
  • Torch light
    The DMC-FT5 features a torch light that records beautiful videos even in dusky underwater environments or at a nighttime camp. It is also possible to turn only light on to light up subject even while camera function is not activated.
  • Advanced underwater mode
    The red color reproduction of advanced underwater mode compensates for the red color which is easily lost in underwater shooting to look underwater picture more natural. Sports, Snow and beach & snorkeling mode can also be selected easily and quickly from the menu.
  • Manual exposure
    The DMC-FT5 provides easy-to-use manual controls. You can set the aperture to control the depth of field, and adjust the shutter speed to freeze moving subjects or create a motion blur that exaggerates the feeling of movement.
  • iA (Intelligent Auto) mode
    In the iA (Intelligent Auto) mode, the camera does all the work, leaving you free to compose your shot and capture the moment. You just press, aim and shoot. The detection and correction functions go to work to give you beautiful photos and videos with maximum ease.
Panasonic Lumix DMC-FT5 - digital camera - Leica
Digital camera - compact
Lens Included
Leica
Memory Card Slot
SD card
Image Processor
Venus Engine
Sensors
Barometer, magnetometer, altimeter
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 4.6x zoom - 4.9 - 22.8 mm - f/3.3-5.9
Focus Adjustment
Automatic
Min Focus Distance
30 cm
Digital Zoom
4x
Image Stabiliser
Optical (POWER O.I.S.)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery - 1250 mAh (included)
Composite video/audio, HDMI, USB 2.0
Orange
10.92 cm x 2.89 cm x 6.74 cm
188 g
Lens Included
Leica
Built-in Light
LED lights
Enclosure Colour
Orange
Sensor Resolution
16.1 Megapixel
Optical Sensor Type
CMOS
Total Pixels
17,500,000 pixels
Effective Sensor Resolution
16,100,000 pixels
Optical Sensor Size
1/2.33"
ISO (Max)
6400
Optical Zoom
4.6x
Digital Zoom
4x
Image Processor
Venus Engine
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Navigation
GPS receiver, GPS/GLONASS receiver
Sensors
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
23
AE/AF Control
Subject-tracking AF
Face Detection
Face Recognition
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, MPO
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO auto (1600-6400)
Exposure Metering
Multi-segment
Exposure Modes
Programme, automatic
Shooting Programs
Portrait mode, night portrait, PET, scenery, food, night scene, sunset, behind glass, high sensitivity, starry sky, soft skin, baby1, baby2, handheld night shot, Dynamic Range (HDR)
Special Effects
Black & White, Sepia, Vivid, miniature, Cross Process, Retro, Happy, Expressive, high dynamic, High Key, Low Key, Toy effect, Star Filter, Impressive Art, One Point Colour, Dynamic Monochrome
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, daylight, shade
Max Shutter Speed
1/1300 sec
Min Shutter Speed
30 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
Lens System
Leica zoom lens - 4.6x zoom - 4.9 - 22.8 mm - f/3.3-5.9
Focal Length Equivalent to 35mm Camera
28 - 128mm
Focus Adjustment
Automatic
Min Focus Distance
30 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
8 groups / 10 elements
ED glass, aspherical lens, anti-fog coating
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.3 m - 5.6 m: ISO auto (wide lens) , 1 m - 3.1 m: ISO auto (wide lens)
Additional Features
Continuous Shooting Speed
2 frames per second, 5 frames per second, 40 frames per second (5MP), 60 frames per second (2.5MP), 10 frames per second for 7 frames
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, built-in speaker, date/time stamp, histogram display, in-camera red-eye removal, cropping an image, resizing an image, Intelligent Scene Selector, in-camera film editing, Intelligent Resolution Technology, face detection, automatic display brightness adjustment, Intelligent Auto (iA), text input to Exif header, Time-Lapse recording, primary colour filter, Intelligent HDR mode, Wi-Fi Direct
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities, Adobe Reader, Panasonic PHOTOfunSTUDIO 9.1 Premium Edition
Battery charger, hand strap, USB cable
Protection
Waterproof, freezeproof, shockproof, dust-resistant
Underwater Use
Underwater Depth
Up to 13 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 370 shots
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2560 x 1920 , JPEG 2560 x 1712 , JPEG 2560 x 1440 , JPEG 2048 x 1536 , JPEG 2048 x 1360 , JPEG 1920 x 1080 , JPEG 1280 x 960 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3456 x 3456 , JPEG 2736 x 2736 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1280 x 720 - 50 fps - 17Mbps , H.264 - 1920 x 1080 - 25 fps - 20Mbps , H.264 - 1280 x 720 - 25 fps - 10Mbps , H.264 - 640 x 480 - 25 fps - 4Mbps
10.92 cm
2.89 cm
6.74 cm
188 g
-10 °C
