Panasonic KX-TGF320E Corded/Cordless Combo with TAM
Quicklinx: BXS2WS00 Mfr#: KX-TGF320E
£53.22 ex VAT
£63.86 inc VAT
A dedicated call block button enables you easily register to the call block list. During an electric power failure, the power stored in batteries can be supplied to the base unit. This allows you to make a call with handset even when the power is out. You can block any specified number, as well as any head string of 2 to 8 digits matching your specified numbers or numberless calls. Communications between the cordless handset and base unit are encrypted, and the encryption password is periodically changed to maintain a high level of security.
  • Easy-to-see large tiltable display
    3.4-inch (8.6 cm) large white illuminated display with tilt function.
  • One-touch dialing buttons
    Enable you to dial with a simple one-touch operation.
  • Dedicated call block button on the base unit
  • Battery backup for unexpected power failures
  • Reduce unwanted calls such as telemarketers
    You can block any specified number, as well as any head string of 2 to 8 digits matching your specified numbers or numberless calls 2.
  • Protect calls
  • Do Not Disturb mode
    Never disturb your sound sleep despite staying available to your important ones. Each handset can be programmed to prevent ringing during specific periods. However, the sound of the special callers by placing them in a contacts group of the phonebook can be turned on.
  • Advanced Answering System
    Catch answering machine calls whether you are at home or away.
  • Smoothly conduct teleconferences
    The speakerphone enables bidirectional conversation for smooth teleconferences with the lively exchange of opinions.
  • Easily register to the phonebook
    Dial information registered to the phonebook can be shared with the base unit and all handsets to reduce phonebook registration work. The existing phonebook can also be used immediately when new handsets are added.
Panasonic KX-TGF320 - corded/cordless - answering system with caller ID
Corded/cordless answering system with caller ID
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Caller ID, Call Waiting, Call Transfer
Display
LCD display - monochrome - Yes
Display (2nd)
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
6
Dialer Location
Handset, base
Conference Call Capability
3-way
Speakerphone
Polyphonic Ringer
Additional Functions
Alarm, built-in clock with snooze function, Intercom
Phone Memory
Phone Directory Capacity
100 names & numbers
Dialed Calls Memory
10
One-Touch Dial Button Qty
3
Caller ID Memory
50 names & numbers
Answering System
Recording Capacity
40 min
Display
Display Location
Base
Diagonal Size
3.4"
Backlit
Display (2nd)
LCD display
Colour Support
Monochrome
Display Location
Handset
Backlit
Headset jack
Phone line cable
Belt clip
2 x battery - AAA type
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 1020 min
Standby Time
Up to 330 h
Recharge Time
7 hour(s)
Dimensions & Weight (Base)
22.2 cm
16.3 cm
10.3 cm
580 g
Dimensions & Weight (Handset)
4.8 cm
3 cm
16.8 cm
140 g
Type: Corded/cordless
Brand: Panasonic
Price Range Ex VAT: 50 - 100
