Your basket is empty
Panasonic KX-TCA285 DECT Phone
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 9D4MWS00 Mfr#: KX-TCA285UK
Reflecting Panasonic's aim of providing technology that integrates easily into working lives, the KX-TCA285 DECT handset is slim and light, making it perfect for highly mobile, active professional environments.
To ensure efficient, comfortable and clear communication, the KX-TCA285 is equipped with a noise reduction function, which can be enabled at the press of a button. This function reduces surrounding noise and makes the speaker's voice far easier to hear and understand.
Additionally, the KX-TCA285 automatically adjusts the receiver volume to an easy-to-hear level if it detects noise when moving from a quiet place to a noisy place, providing comfortable voice calls without stress.
Because work in factories, the healthcare and retail industries often requires both hands to be used, it can be difficult to communicate while holding a phone. The KX-TCA285 supports Bluetooth, which enables you to communicate using a cable-free headset while working, leading to improved work efficiency.
Panasonic KX-TCA285 - wireless digital phone - Bluetooth interface
Wireless digital phone Bluetooth interface
Total Number of Wireless Handsets
1
Compatible Platforms
Panasonic KX-NS1000
Cordless Phone Standard
DECT
Speakerphone
Yes (digital duplex)
Call Services
Message Waiting Capability
Display
LCD display - colour - Yes
Panasonic KX-NS1000
1
Phone Features
DECT
Call Services
Multi-Handset Configuration
Phonebook transfer via Bluetooth
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
Speakerphone
Menu Operation
Ring Tones
27
Indicators
Voice message waiting indicator
Additional Functions
Additional Features
Noise reduction, vibration alert
Phone Memory
Phone Directory Capacity
500 names & numbers
Dialed Calls Memory
5
Caller ID Memory
10 names & numbers
Display
Display Location
Handset
Diagonal Size
1.8"
Colour Depth
16-bit (65000 colours)
Backlit
Headset jack / sub-mini-phone 2.5mm
Belt clip
1 x battery
Rechargeable - Lithium Ion
Included Qty
1
Talk Time
Up to 780 min
Standby Time
Up to 200h
Recharge Time
3 hour(s)
Dimensions & Weight (Handset)
4.85 cm
1.79 cm
12.75 cm
88 g
