Panasonic KV-S7075C is a high-speed color flatbed document scanner with ADF.
Now you can consecutively scan ADF and flatbed documents in one simple operation, greatly improving your productivity.
Place various sized documents on the flatbed, such as checks, ID cards, and business cards, and the KV-S7075C will scan them in one pass and produce multiple individually cropped images!
Documents of different sizes and thicknesses can be difficult to scan, especially when they are part of the same batch. The KV-S7075C can accommodate them all at once thanks to it's ability to left, right or center justify the scan guides.
As with Panasonic's other award-winning document scanners, the KV-S7075C supports a variety of image enhancement functions built right into it. Auto-crop, dynamic thresholding, auto/binary distinction, blank paper removal, hole removal and multi-color dropout are just a few of the available features found on every Panasonic document scanner.
- Panasonic KV-S7075C - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- A3 (297 x 420 mm)
- Localisation
- Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 95 ppm (mono) / 95 ppm (colour)
- Max Document Size
- 302 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 230V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP 32-bit
- 75.5 cm x 50.8 cm x 28.9 cm
- 29 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
- Localisation
- Europe
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Max Document Scan Speed B/W
- 95 ppm
- Max Document Scan Speed Colour
- 95 ppm
- Duty Cycle
- Scanner Speed Details
- 75 ppm - portrait B&W - A4 - 200 dpi , 150 ipm - duplex - portrait B&W - A4 - 200 dpi , 95 ppm - landscape B&W - A4 - 200 dpi , 190 ipm - duplex - landscape B&W - A4 - 200 dpi , 75 ppm - portrait colour - A4 - 200 dpi , 150 ipm - duplex - portrait colour - A4 - 200 dpi , 95 ppm - landscape colour - A4 - 200 dpi , 190 ipm - duplex - landscape colour - A4 - 200 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Double Exposure, Blank Page Removal, Automatic Binary / Color Distinction, Auto Crop, Auto Deskew, Smooth Background
- TWAIN, ISIS
Media Handling
- Max Document Size
- 302 mm x 2540 mm
- Plain paper
- Supported Document Size Details
- Flatbed - up to 297 x 432 mm , ADF - up to 302 x 2540 mm
- Automatic
- 200 sheets
- USB 2.0 - Type B
- Included Accessories
- Blower, roller cleaning paper, shading paper
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities, QuickScan Pro (Demo), Image Capture Plus
- OS Required
- 75.5 cm
- 50.8 cm
- 28.9 cm
- 29 kg
- 10 °C
- 35 °C
- 30 - 80%
