Panasonic KV-S4085CW Document Scanner
Quicklinx: 9KYRWS00 Mfr#: KV-S4085CW-U
  • Windows 8 (32/64 bits)
The KV-S4085C has high quality image processing including automatic binary/color distinction, multi color dropout, and automatic crop/de-skew. The clamshell design allows full, easy access to the entire paper path, so you can clear paper jams or clean the unit easily.
Panasonic KV-S4085CW-U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Hybrid CIS/CCD
Max Supported Document Size
302 x 2540 mm
Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
302 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
50000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit
47.4 cm x 58.5 cm x 32.9 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
302 x 2540 mm
Europe
Scanner
Input Type
Grayscale Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Hybrid CIS/CCD
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
50000 scans per day
Scanner Speed Details
100 ppm - landscape B&W - A4 / Letter - 200 dpi , 200 ipm - duplex - landscape B&W - A4 / Letter - 200 dpi , 100 ppm - landscape B&W - A4 / Letter - 300 dpi , 200 ipm - duplex - landscape B&W - A4 / Letter - 300 dpi , 85 ppm - portrait B&W - Letter - 300 dpi , 80 ppm - portrait B&W - A4 - 300 dpi , 170 ipm - duplex - portrait B&W - Letter - 300 dpi , 160 ipm - duplex - portrait B&W - A4 - 300 dpi , 100 ppm - landscape colour - A4 / Letter - 200 dpi , 100 ppm - landscape colour - A4 / Letter - 300 dpi , 200 ipm - duplex - landscape colour - A4 / Letter - 300 dpi , 85 ppm - portrait colour - Letter - 300 dpi , 80 ppm - portrait colour - A4 - 300 dpi , 170 ipm - duplex - portrait colour - Letter - 200 dpi , 170 ipm - duplex - portrait colour - Letter - 200 dpi , 160 ipm - duplex - portrait colour - A4 - 200 dpi , 160 ipm - duplex - portrait colour - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, double feed prevention roller system, Multi Color Dropout, Black Page Removal, Double Exposure, De-skewing, Automatic Separation, Noise Reduction, Long Paper Mode, Dynamic Threshold, Blank Page Removal, Error Diffusion, Patch Code Detection, Separation Sheet Detection, Barcode Detection, Intelligent Feed Control, Automatic Binary / Color Distinction, Mixed Document Feeding, Dither, MultiStream Technology, Auto Crop, Auto Deskew, Smooth Background, White Level from Paper, Detect Control, Punch Hole Removal
TWAIN, ISIS
Media Handling
Max Document Size
302 mm x 2540 mm
Automatic
300 sheets
Interfaces Details
USB 2.0
Blower, roller cleaning paper, shading paper, control sheet
1 x USB cable
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, QuickScan Pro (Demo), RTIV, Image Capture Plus, Multi Color Dropout
47.4 cm
58.5 cm
32.9 cm
25 kg
Limited warranty - replacement - 1 year - shipment
15 °C
30 °C
20 - 80%
