Your basket is empty
Panasonic KV-S4085CL Document Scanner
Quicklinx: 9KYQWS00 Mfr#: KV-S4085CL-U
Marketing description is not available.
Panasonic KV-S4085CL-U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
A4 (210 x 297 mm)
Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
227 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Manual, automatic
Document Storage Capacity
300 sheets
47.4 cm x 58.5 cm x 32.9 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A4 (210 x 297 mm)
Europe
Scanner
Input Type
Grayscale Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Scanner Speed Details
80 ppm - portrait B&W - A4 - 200 dpi , 160 ipm - duplex - portrait B&W - A4 - 200 dpi , 100 ppm - landscape B&W - A4 - 200 dpi , 200 ipm - duplex - landscape B&W - A4 - 200 dpi , 80 ppm - portrait B&W - A4 - 300 dpi , 160 ipm - duplex - portrait B&W - A4 - 300 dpi , 100 ppm - landscape B&W - A4 - 300 dpi , 200 ipm - duplex - landscape B&W - A4 - 300 dpi , 80 ppm - portrait colour - A4 - 200 dpi , 160 ipm - duplex - portrait colour - A4 - 200 dpi , 100 ppm - landscape colour - A4 - 200 dpi , 200 ipm - duplex - landscape colour - A4 - 200 dpi , 80 ppm - portrait colour - A4 - 300 dpi , 160 ipm - duplex - portrait colour - A4 - 300 dpi , 100 ppm - landscape colour - A4 - 300 dpi , 200 ipm - duplex - landscape colour - A4 - 300 dpi
Scanner Features
Double Exposure, Double feed detection, Blank Page Removal, Automatic Binary / Color Distinction, Smooth Background
TWAIN, ISIS
Media Handling
Max Document Size
227 mm x 2540 mm
Plain paper
Manual, automatic
300 sheets
USB 2.0
Blower, roller cleaning paper, shading paper
1 x USB cable
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, QuickScan Pro (Demo), RTIV, Image Capture Plus
47.4 cm
58.5 cm
32.9 cm
25 kg
10 °C
35 °C
20 - 80%
