Offering a stunning array of performance, efficiency and reliability, Panasonic's KV-S4065CL low-volume production scanner is optimized for deployment in organizations with heavy volumes of paperwork. With the ability to scan virtually any type of document, from business cards to legal size paper, the KV-S4065CL is an essential solution for any organization with a steady flow of scanning.
Beyond standard documents, the KV-S4065CL also features the ability to scan continuous documents of up to 100" in length such as EKG reports or well logs. With available ToughFeed technology, it utilizes ultrasonic double-feed sensors and staple detection to safeguard against any disruptions to the scan process.
Featuring a sturdy, dependable construction and a rugged and durable design, the KV-S4065CL fits comfortably into any low-volume scanning environment. Whether it's scanning a single page or a full stack of documents, the KV-S4065CL provides you with an exceptionally powerful and robust scanning solution.
300 page ADF
A large capacity ADF (Automatic Document Feeder) is an essential part of any scanning experience. Users simply place up to the allotted document capacity into the ADF in the tray and start the scan job. This allows for an easily managed scan process, and saves users time by eliminating the need to individually feed pages one by one through the scanner. -
Mixed size document feeding
The ability to handle "mixed size document feeding" is an essential feature for any situation in which the scanner user may encounter the need to scan a multitude of different sized documents. This helps save time by feeding documents of varied sizes at the same time, from business cards to the maximum document size, without the hassle of having to continuously stop the scanning process to adjust settings or guide rails. -
Stapled document detection
To prevent documents with staples from going through the scanner and damaging the scanning glass, "stapled document detection" uses a sensor to detect various types of stapled documents and immediately stop the scanner when they are detected. This minimizes damage to both the document and the scanning glass, and keeps your scanning glass in excellent condition. -
Ultrasonic double-feed sensor
For advanced worry-free scanner operation, an "ultrasonic double-feed sensor" is equipped within the scanner for versatile detection of items such as sticky notes or small documents mixed in among regular sized documents. These innovative, high-performance sensors can detect even subtle changes, and immediately stop the scanning operation so that the double-feed can be recovered. Thanks to these double-feed sensors, optimum reliability is assured even when scanning high volumes of documents. -
Intelligent feed control
Ensuring accurate document feeding, "intelligent feed control" checks the condition of the paper feed and automatically adjusts roller pressure and the ADF tray to ensure that documents of various thicknesses are accurately fed. This makes document feeding more reliable and accurate than conventional methods that only use a basic feed mechanism. -
Double-feed prevention roller
Ensuring reliable scanning of large amounts of documents, the "double-feed prevention roller" helps prevent scanning mis-feeds. Assisting the document feeding process, the double-feed prevention roller separates the feeding documents from the second sheet onward. This reduces, and ultimately helps to prevent the number of occurrences of sheets coming through as a double-feed. -
Long paper mode
Long paper mode allows documents of up to 100 inches in length to be scanned in one single scan job. This feature was designed for scanning electrocardiograms (EKG), well logs, exceptionally long receipts or any other special documents. The highly reliable paper feed system ensures that these documents are scanned straight through as a single scan job. -
Easy user maintenance
Panasonic scanners are designed with the comfort and ease of use of the scanner user in mind. The clamshell design allows for full, easy access to the main paper path for easy user maintenance. This allows scanner users to effortlessly clear the occasional paper jam, clean the unit or replace the rollers without having to call a service technician. -
Advanced Hybrid Scanning technology
To create the very best possible image, this scanner incorporates "Advanced Hybrid Scanning technology". This combines a CIS (Contact Image Sensor) along with CCD (Charge-Coupled Device) to create a scanner with high-precision scanning technology. This hybrid system, coupled with a highly-luminous LED lamp, enables higher quality image scanning and provides the best possible image output.
- Panasonic KV-S4065CL-U - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Hybrid CIS/CCD
- Max Supported Document Size
- 227 x 2540 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 80 ppm (mono) / 80 ppm (colour)
- Max Document Size
- 227 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 300 sheets
- Duty Cycle
- 30000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit
- 47.4 cm x 58.5 cm x 32.9 cm
- 25 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 227 x 2540 mm
Scanner
- Input Type
- Grayscale Depth
- 600 dpi x 600 dpi
- Hybrid CIS/CCD
- Max Document Scan Speed B/W
- 80 ppm
- Max Document Scan Speed Colour
- 80 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ppm - landscape B&W - A4 / Letter - 200 dpi , 160 ipm - duplex - landscape B&W - A4 / Letter - 200 dpi , 80 ppm - landscape B&W - A4 / Letter - 300 dpi , 160 ipm - duplex - landscape B&W - A4 / Letter - 300 dpi , 65 ppm - portrait B&W - Letter - 300 dpi , 60 ppm - portrait B&W - A4 - 300 dpi , 130 ipm - duplex - portrait B&W - Letter - 300 dpi , 120 ipm - duplex - portrait B&W - A4 - 300 dpi , 80 ppm - landscape colour - A4 / Letter - 200 dpi , 80 ppm - landscape colour - A4 / Letter - 300 dpi , 160 ipm - duplex - landscape colour - A4 / Letter - 200 dpi , 160 ipm - duplex - landscape colour - A4 / Letter - 300 dpi , 65 ppm - portrait colour - Letter - 200 dpi , 65 ppm - portrait colour - Letter - 300 dpi , 60 ppm - portrait colour - A4 - 200 dpi , 60 ppm - portrait colour - A4 - 300 dpi , 130 ipm - duplex - portrait colour - Letter - 200 dpi , 130 ipm - duplex - portrait colour - Letter - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 300 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, double feed prevention roller system, Multi Color Dropout, Black Page Removal, Double Exposure, De-skewing, Automatic Separation, Noise Reduction, Long Paper Mode, Dynamic Threshold, Blank Page Removal, Error Diffusion, Patch Code Detection, Separation Sheet Detection, Barcode Detection, Intelligent Feed Control, Automatic Binary / Color Distinction, Mixed Document Feeding, Dither, MultiStream Technology, Auto Crop, Auto Deskew, Smooth Background, White Level from Paper, Detect Control, Punch Hole Removal
- TWAIN, ISIS
Media Handling
- Max Document Size
- 227 mm x 2540 mm
- Plain paper
- Automatic
- 300 sheets
- USB 2.0
- Included Accessories
- Blower, roller cleaning paper, shading paper, control sheet
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- (5.3 Watt)
- Software Included
- Drivers & Utilities, QuickScan Pro (Demo), RTIV, Image Capture Plus, Multi Color Dropout
- OS Required
- 47.4 cm
- 58.5 cm
- 32.9 cm
- 25 kg
- Limited warranty - replacement - 1 year - shipment
- 15 °C
- 30 °C
- 20 - 80%
