Panasonic WV-SF132E.
Placement supported: Indoor & outdoor.
Form factor: Dome.
Colour of product: White.
Mounting type: Wall.
Maximum resolution: 640 x 480 pixels.
Supported video modes: 720p.
Camera shutter speed: 1/8000.
Sensor type: MOS.
- Panasonic i-Pro Smart HD WV-SF132E - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- Camera Mount Type
- Wall mount, ceiling mount
- 10 cm x 10 cm x 4.7 cm
- 200 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night - PAL
- Max Resolution
- 640 x 480
- Frame Rate (max)
- 30 images per second
- Motion Detection
- Optical Sensor Type
- MOS - 1/5" - 0.32 MP
- Minimum Illumination
- 2 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 1.3 lux - B&W - F2.9 - shutter 8/30 sec / AGC High , 0.3 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 0.16 lux - B&W - F2.9 - shutter 8/30 sec / AGC High
- Focal Length Control
- Fixed focal
- Focal Length
- 1.95 mm
- Lens Iris
- F/2.9
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 48 V / PoE
- RGB primary colour filter, digital noise reduction, progressive scanning, e-mail alerts, automatic electronic shutter, Adaptive Black Stretch (ABS), ONVIF support, 3D Noise Reduction Technology, face detection, Electronic light control (ELC), UniPhier LSI platform, Video Motion Detector (VMD), Variable Image Quality on Specified area (VIQS), Video Motion Detection Technology, auto gain control, auto white balance
- Environmental Parameters (operating)
- 0 °C - 40 °C; 0 - 90% (non-condensing) relative humidity
- Form Factor
- Dome
- Camera Mount Type
- Wired
- 10 cm
- 10 cm
- 4.7 cm
- 200 g
Camera
- Colour - Day&Night - fixed
- Video Format
- PAL
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 640 x 480
- Motion Detection
- Digital Zoom
- 4
- Exposure Range
- 1/30 sec - 1/8000 sec
- Video Capture
- 640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 640 x 360 @ 30 fps , 320 x 180 @ 30 fps
- Supported Image Formats
- JPEG
- Still Image Capture Resolution
- 640 x 480, 320 x 240, 640 x 360, 320 x 180
Image Sensor
- 0.32 MP MOS 1/5"
Lens Construction
- Fixed focal
- Focal Length
- 1.95 mm
- Lens Iris
- F/2.9
- Horizontal Field of View (degree)
- 68
- Vertical Field of View (degree)
- 53
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, SSL
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- White
- Power Requirements
- DC 48 V / PoE - 46 mA
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90% (non-condensing)
