Product
Panasonic i-Pro Smart Network Camera
Quicklinx: 9RBJWS00 Mfr#: WV-SF132E
Panasonic WV-SF132E.
Placement supported: Indoor & outdoor.
Form factor: Dome.
Colour of product: White.
Mounting type: Wall.
Maximum resolution: 640 x 480 pixels.
Supported video modes: 720p.
Camera shutter speed: 1/8000.
Sensor type: MOS.
Panasonic i-Pro Smart HD WV-SF132E - network surveillance camera
Network surveillance camera - fixed dome
Camera Mount Type
Wall mount, ceiling mount
10 cm x 10 cm x 4.7 cm
200 g
White
Wired
Camera
Colour - Day&Night - PAL
Max Resolution
640 x 480
Frame Rate (max)
30 images per second
Motion Detection
Optical Sensor Type
MOS - 1/5" - 0.32 MP
Minimum Illumination
2 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 1.3 lux - B&W - F2.9 - shutter 8/30 sec / AGC High , 0.3 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 0.16 lux - B&W - F2.9 - shutter 8/30 sec / AGC High
Focal Length Control
Fixed focal
Focal Length
1.95 mm
Lens Iris
F/2.9
Ethernet 10Base-T/100Base-TX
Voltage
DC 48 V / PoE
RGB primary colour filter, digital noise reduction, progressive scanning, e-mail alerts, automatic electronic shutter, Adaptive Black Stretch (ABS), ONVIF support, 3D Noise Reduction Technology, face detection, Electronic light control (ELC), UniPhier LSI platform, Video Motion Detector (VMD), Variable Image Quality on Specified area (VIQS), Video Motion Detection Technology, auto gain control, auto white balance
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 90% (non-condensing) relative humidity
Camera Mount Type
Wired
10 cm
10 cm
4.7 cm
200 g
Camera
Colour - Day&Night - fixed dome
Video Format
PAL
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
640 x 480
Motion Detection
Digital Zoom
4
Exposure Range
1/30 sec - 1/8000 sec
Video Capture
640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 640 x 360 @ 30 fps , 320 x 180 @ 30 fps
Supported Image Formats
JPEG
Still Image Capture Resolution
640 x 480, 320 x 240, 640 x 360, 320 x 180
Image Sensor
0.32 MP MOS 1/5"
Lens Construction
Fixed focal
Focal Length
1.95 mm
Lens Iris
F/2.9
Horizontal Field of View (degree)
68
Vertical Field of View (degree)
53
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, SSL
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
White
Power Requirements
DC 48 V / PoE - 46 mA
Relative Humidity (operating)
