The projector offers a maintenance-free operational life of 7,000 hours when set to eco mode, significantly reducing the Total Cost of Ownership for businesses and educational institutions.
All six models allow both portable and ceiling-mounting, while vertical lens shift and screen adjustment functionality means easy adjustment of images projected onto flat or curved surfaces, as well as angled projection.
- Panasonic PT-VZ570AJ - LCD projector
- LCD projector - 1080p
- Built-in Devices
- Speaker
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 5000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Vertical
- Bulb type
- UHM 270 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 38.9 cm x 33.2 cm x 12.5 cm
- 4.9 kg
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 5000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.1 - 1.8:1
- Uniformity
- 85 %
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Video Bandwidth
- 162 MHz
- Display Format
- 2,304,000 pixels (1920 x 1200) x 3
- Max Sync Rate (V x H)
- 100 Hz x 91 kHz
- Bulb type
- UHM 270 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Deep Color, Split Screen, PJlink, AMX Device Discovery, Direct Power Off, Crestron e-Control, Colourboard Mode, Dynamic Mode, Eco Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6-2.12
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -25 / +25
- Horizontal Keystone Correction
- -30 / +30
- Vertical
- Vertical Lens Shift
- 44%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel - 4 cm
- 1 x HDMI input - 19 pin HDMI Type A , 1 x composite / component video / RGB input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
- Included Accessories
- 2 x AAA batteries, wireless remote control, cable holder
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- Software Included
- Logo Transfer Software, Multi Projector Monitoring & Control Software
- 38.9 cm
- 33.2 cm
- 12.5 cm
- 4.9 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
