The 3MOS System PRO is comprised of the F1.5 LEICA Dicomar Lens, the 3MOS Sensor, and Crystal Engine Pro II. In addition to the excellent color reproduction and high-resolution that the 3MOS system is known for, the 3MOS System PRO delivers greatly enhanced image quality, especially in dimly lit situations, and achieves twice the sensitivity. Horizontal resolution of 1080 TV lines makes it possible to shoot high-resolution Full-HD images that express small details.
A manual ring is provided to meet the needs of photographers who want to have full control over operations. The large manual ring allows intuitive operation of iris, zoom, focus, shutter speed and white balance. The Level Gauge visibly assists you to shoot straight with horizontal and vertical level gauge. The extendable 263,424-dot equivalent EVF is easy to use and convenient for focusing and other adjustments. It makes it easy to see the shooting scene under bright sunlight that makes the LCD difficult to see.
- Panasonic HC-X920 - camcorder - Leica - storage: flash card
- Product Type
- Camcorder - 1080p
- Lens Included
- Leica
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Image Processor
- Crystal Engine PRO II
- Sensors
- Digital level metre
- Wireless Interface
- Wi-Fi
- Sensor Resolution
- 12.76 MP
- Effective Sensor Resolution
- Video: 2.83 MP - Photo: 2.83 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 12x zoom - 2.84 - 34.1 mm - f/1.5-2.8
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 700x
- Image Stabiliser
- Optical (HYBRID O.I.S. + with Active Mode)
- Camera Flash
- Built-in flash
- Viewfinder
- Built-in - colour - electronic
- Display
- 3D LCD display - 3.5"
- Supported Battery
- Panasonic VW-VBN130 Li-ion rechargeable battery - 1250 mAh (included) , Panasonic VW-VBN260 Li-ion rechargeable battery - 2500 mAh (optional)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 6.7 cm x 15 cm x 7.2 cm
- 417 g
- Product Type
- Camcorder - 1080p
- Lens Included
- Leica
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 12.76 MP
- Sensor Qty
- 3 MOS
- Effective Video Resolution
- 2.83 MP
- Effective Photo Resolution
- 2.83 MP
- Camcorder Interpolated Photo Resolution
- 20.4 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- BSI 3MOS
- Optical Sensor Size
- 1/2.3"
- Optical Zoom
- 12x
- Digital Zoom
- 700x
- Image Processor
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Surround Sound
- Dolby Digital 5.1 channel recording
- Sensors
- Print Standard
- Exif Print support
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Face Recognition
- Digital Video Format
- AVCHD, iFrame, MVC
- Image Recording Format
- JPEG, MPO
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
Exposure & White Balance
- Min Illumination
- 1 lux
- Special Effects
- Miniature, 8mm Movie, Silent Movie
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, sunlight, indoor
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Leica zoom lens - 12x zoom - 2.84 - 34.1 mm - f/1.5-2.8
- Focal Length Equivalent to 35mm Camera
- 29.8 - 399.2mm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Motorised drive
- Filter Size
- 49 mm
- Built-in lens shield
Camera Flash
- Camera Flash
- Built-in flash
Additional Features
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, Intelligent Scene Selector, takes photos while film recording, Intelligent Contrast Control, Pre-Rec function, Auto Ground-Directional Standby (AGS), Live Broadcasting, Intelligent Auto Plus (iA+), touch panel control, Touch Shutter technology, Time-Lapse recording, Level Shot Function
Viewfinder
- Viewfinder Type
- Built-in - electronic
- Viewfinder Colour Support
- Viewfinder Resolution
- 263,424 pixels
Display
- 3D 3.5" LCD display
- Display Format
- 1,152,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Colour control
Microphone
- Microphone Operation Mode
- Surround
- Microphone Features
- Zoom, wind noise reduction
- Connector Type
- HDMI output , USB 2.0 , Composite video/audio output , Headphones , Microphone , DC power input
Software
- Software
- Panasonic HD Writer AE 5.0
- Included Accessories
- Lens hood, AC power adaptor, accessory shoe adaptor, USB cable, A/V cable, HDMI cable
- Battery Type
- Panasonic VW-VBN130 Lithium Ion
- Details
- Battery Life Details
- Video recording - 1.4 hours (EVF on) , Video recording - 1.3 shots (LCD Monitor on)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 6016 x 3384 , JPEG 4096 x 2304 , JPEG 1920 x 1080 , JPEG 4896 x 3264 , JPEG 3456 x 2304 , JPEG 1728 x 1152 , JPEG 4480 x 3360 , JPEG 2784 x 2088 , JPEG 640 x 480 , MPO 1920 x 1080 - 3D mode
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 50 fps - 13Mbps , AVCHD - 1920 x 1080 - 50 fps - 5Mbps , iFrame - 960 x 540 - 28Mbps , MVC - 1920 x 1080 - 28Mbps - 3D HD , MVC - 1920 x 1080 - 17Mbps - side-by-side
- 6.7 cm
- 15 cm
- 7.2 cm
- 417 g
- 0 °C
- 40 °C
