Panasonic HC-X920 3D 12x Zoom HD Camcorder - Black
Quicklinx: 9JYKWS00 Mfr#: HC-X920EB-K
  • SDHC Memory Card
The 3MOS System PRO is comprised of the F1.5 LEICA Dicomar Lens, the 3MOS Sensor, and Crystal Engine Pro II. In addition to the excellent color reproduction and high-resolution that the 3MOS system is known for, the 3MOS System PRO delivers greatly enhanced image quality, especially in dimly lit situations, and achieves twice the sensitivity. Horizontal resolution of 1080 TV lines makes it possible to shoot high-resolution Full-HD images that express small details.
A manual ring is provided to meet the needs of photographers who want to have full control over operations. The large manual ring allows intuitive operation of iris, zoom, focus, shutter speed and white balance. The Level Gauge visibly assists you to shoot straight with horizontal and vertical level gauge. The extendable 263,424-dot equivalent EVF is easy to use and convenient for focusing and other adjustments. It makes it easy to see the shooting scene under bright sunlight that makes the LCD difficult to see.
Panasonic HC-X920 - camcorder - Leica - storage: flash card
Camcorder - 1080p
Lens Included
Leica
Media Type
Flash card
Memory Card Slot
SD card
Image Processor
Crystal Engine PRO II
Sensors
Digital level metre
Wireless Interface
Wi-Fi
Sensor Resolution
12.76 MP
Effective Sensor Resolution
Video: 2.83 MP - Photo: 2.83 MP
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 12x zoom - 2.84 - 34.1 mm - f/1.5-2.8
Focus Adjustment
Automatic, manual
Digital Zoom
700x
Image Stabiliser
Optical (HYBRID O.I.S. + with Active Mode)
Camera Flash
Built-in flash
Viewfinder
Built-in - colour - electronic
Display
3D LCD display - 3.5"
Supported Battery
Panasonic VW-VBN130 Li-ion rechargeable battery - 1250 mAh (included) , Panasonic VW-VBN260 Li-ion rechargeable battery - 2500 mAh (optional)
Composite video/audio, HDMI, USB 2.0
6.7 cm x 15 cm x 7.2 cm
417 g
Camcorder - 1080p
Lens Included
Leica
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
12.76 MP
Sensor Qty
3 MOS
Effective Video Resolution
2.83 MP
Effective Photo Resolution
2.83 MP
Camcorder Interpolated Photo Resolution
20.4 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
BSI 3MOS
Optical Sensor Size
1/2.3"
Optical Zoom
12x
Digital Zoom
700x
Image Processor
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital 5.1 channel recording
Sensors
Digital level metre
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Face Detection
Face Recognition
Digital Video Format
AVCHD, iFrame, MVC
Image Recording Format
JPEG, MPO
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
Exposure & White Balance
Min Illumination
1 lux
Special Effects
Miniature, 8mm Movie, Silent Movie
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, sunlight, indoor
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/2 sec
Lens System
Leica zoom lens - 12x zoom - 2.84 - 34.1 mm - f/1.5-2.8
Focal Length Equivalent to 35mm Camera
29.8 - 399.2mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
49 mm
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, Intelligent Scene Selector, takes photos while film recording, Intelligent Contrast Control, Pre-Rec function, Auto Ground-Directional Standby (AGS), Live Broadcasting, Intelligent Auto Plus (iA+), touch panel control, Touch Shutter technology, Time-Lapse recording, Level Shot Function
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Resolution
263,424 pixels
Display
3D 3.5" LCD display
Display Format
1,152,000 pixels
Display Form Factor
Rotating
Display Features
Colour control
Microphone
Microphone Operation Mode
Surround
Microphone Features
Zoom, wind noise reduction
Connector Type
HDMI output , USB 2.0 , Composite video/audio output , Headphones , Microphone , DC power input
Software
Software
Panasonic HD Writer AE 5.0
Lens hood, AC power adaptor, accessory shoe adaptor, USB cable, A/V cable, HDMI cable
Battery Type
Panasonic VW-VBN130 Lithium Ion
Details
Battery Life Details
Video recording - 1.4 hours (EVF on) , Video recording - 1.3 shots (LCD Monitor on)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 6016 x 3384 , JPEG 4096 x 2304 , JPEG 1920 x 1080 , JPEG 4896 x 3264 , JPEG 3456 x 2304 , JPEG 1728 x 1152 , JPEG 4480 x 3360 , JPEG 2784 x 2088 , JPEG 640 x 480 , MPO 1920 x 1080 - 3D mode
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 50 fps - 13Mbps , AVCHD - 1920 x 1080 - 50 fps - 5Mbps , iFrame - 960 x 540 - 28Mbps , MVC - 1920 x 1080 - 28Mbps - 3D HD , MVC - 1920 x 1080 - 17Mbps - side-by-side
6.7 cm
15 cm
7.2 cm
417 g
