Your basket is empty
Panasonic DMW-BGGH3 Battery Grip for GH3
Quicklinx: 9V6KWS00 Mfr#: DMW-BGGH3E
The DMW-BGGH3 gives DMC-GH3 longer battery life of more than 1,000 pictures. When using LVF and the battery inside the body is also used. The ergonomically designed DMW-BGGH3 offers comfortable grip and easy handling even in vertical shooting. Three dedicated buttons for exposure, ISO and WB are equipped in addition to the release button on the top as well as the front/ rear dials to be used just in the same way of using the camera DMC-GH3.
The DMW-BGGH3 is dust / splashproof design.
Panasonic DMW-BGGH3E - battery grip
Battery grip
Protection
Splashproof, dust-resistant
12.98 cm x 6.33 cm x 3.95 cm
Lumix G DMC-GH3, DMC-GH3A, DMC-GH3H, DMC-GH3WA, DMC-GH4, DMC-GH4A, DMC-GH4H, DMC-GH4M, DMC-GH4R
Battery grip
Protection
12.98 cm
6.33 cm
3.95 cm
Panasonic Lumix G DMC-GH3, DMC-GH3A, DMC-GH3H, DMC-GH3WA, DMC-GH4, DMC-GH4A, DMC-GH4H, DMC-GH4M, DMC-GH4R
