Panasonic DMC-TZ80 18.1MP 4K Full HD LCD Black Camera
Quicklinx: BZD9WS00 Mfr#: DMC-TZ80EB-S
Resolution: 18.1Megapixel
Optical Zoom: 30
Colour: Silver
£207.50 ex VAT
£249.00 inc VAT
Take this pocket-sized camera on your next trip. Its powerful 30x zoom lens and 4K Video/Photo recording capability let you save your travel memories in exactly the form you want.
  • Big zoom, powerful features, little camera
    With an indispensable 30x optical zoom, 4K Video and 4K Photo technology all in a pocket sized camera. This camera gives you every detail from far away landscapes and allowing you to capture spur of the moment shots in vivid clarity. Capture all of your unmissable moments on your adventure.
  • Powerful engine for low light conditions
    Take stunning photos in dimly lit environments with an 18.1-megapixel High Sensitivity MOS Sensor and Venus Engine (the same quality engine that you find in a LUMIX high-end system camera). Capture and edit more details shooting in RAW format allowing you to retain the original color and light information with minimal processing.
  • Get closer to the moment
    The 24 mm LEICA DC VARIO-ELMAR lens has a 30x optical zoom brings you an intimate view of that unmissable moment during your adventure.
  • Capture unmissable moments with 4K Photo
    4K Photo allows you to capture that unmissable moment in 30fps and select your best photo after shooting.
  • 4K Video, life in vivid detail
    Record your adventure in up to 4x the quality of Full HD; giving you more excitement, detail and vivid unmissable memories.
  • Light composition
    Light Composition function synthesizes the images by choosing and saving a brighter pixel. This makes it possible to produce more luxurious, dramatic image of situations such as fireworks or night scenery in camera with ease.
  • 4K live cropping
    4K Live Cropping enables unique video expressions that were previously difficult to record. Only the recording frame moves while the camera maintains a fixed position. This allows stable panning, and lets you zoom in on a subject that is not in the image's center position.
  • Shoot now, focus later
    Decide what you want in focus, after you've taken the photo. The Post Focus function gives you the power to do just that. Simply capture the scene, review the image and touch the part of the photo you'd like to be pin sharp. A simple feature that will help you capture that stunning shot.
  • High speed auto-focusing with DFD technology
    Panasonic's Depth From Defocus (DFD) Auto Focus (AF) technology instantly calculates the distance between the items inside the frame and drives the focus of the lens in one fast, continuous movement. This system results in faster AF speeds up to 0.1 seconds and a burst shooting speed with AFC of 5 fps. It also increases the stability of continuous focusing when shooting video.
  • Focusing in low light conditions - Star Light AF
    Low Light Auto Focus makes it possible to set focus on the subject more precisely in such as moonlight even without AF assist lamp. Furthermore, the LUMIX TZ80 integrates the Starlight AF to let you shoot a star in the night sky with auto focus by accurate calculation of the contrast value in a smaller AF zone.
Panasonic Lumix DMC-TZ80 - digital camera - Leica
Digital camera - 4K - compact
Lens Included
Leica
Memory Card Slot
SD card
Wireless Interface
Wi-Fi
Sensor Resolution
18.1 Megapixel
Max Video Resolution
3840 x 2160
Lens System
Zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
Focus Adjustment
Automatic
Min Focus Distance
50 cm
Image Stabiliser
Optical (HYBRID O.I.S. +)
Camera Flash
Built-in flash
Viewfinder
Built-in - 0.2" - colour - electronic
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1025 mAh (included)
Composite video/audio, HDMI, USB 2.0
Silver
11.2 cm x 3.8 cm x 6.4 cm
240 g
Lens Included
Leica
Enclosure Colour
Silver
Sensor Resolution
18.1 Megapixel
Optical Sensor Type
CCD
Total Pixels
18,900,000 pixels
Effective Sensor Resolution
18,100,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
25 fps
ISO (Max)
6400
Optical Zoom
30x
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
49
Face Detection
Face Detection AF/AE
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
3840 x 2160
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
Computer Connectivity
Mac, Windows
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Blue Sky, splashing water, night landscape, sports mode, sunset, backlight portrait, night snapshot, baby, soft skin, portrait soft, handheld night shot, monochrome, backlit softness, relaxing tone, romantic sunset glow, clear nightscape, cool night sky, warm glowing nightscape, glittering illuminations, soft image of a flower, appetising food, cute dessert, freeze animal motion, vivid
Special Effects
Vivid, natural, monochrome, landscape, portrait, Standard
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, halogen, shade
Max Shutter Speed
1/2000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±5 EV range, in 1/3 EV steps
Lens System
Leica zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
Focal Length Equivalent to 35mm Camera
24 - 720mm
Focus Adjustment
Automatic
Min Focus Distance
50 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
9 groups / 12 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.6 m - 5.6 m: ISO auto (wide lens) , 2 m - 2.9 m: ISO auto (tele lens)
Additional Features
Continuous Shooting Speed
2 frames per second, 5 frames per second, 10 frames per second
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, digital noise reduction, date/time stamp, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, resizing an image, built-in help guide, in-camera RAW processing, automatic display brightness adjustment
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.2"
Viewfinder Resolution
1,166,000 pixels
Optical Viewfinder Magnification
0.46x
Display
3" LCD display
Display Format
1,400,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 (mini-USB Type B) , HDMI (19 pin micro HDMI Type D)
Battery charger, hand strap, USB cable
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 320 shots
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4896 x 3672 , JPEG 3456 x 2592 , JPEG 2400 x 1800 , JPEG 4896 x 3264 , JPEG 3456 x 2304 , JPEG 2400 x 1600 , JPEG 4896 x 2752 , JPEG 3840 x 2160 , JPEG 1920 x 1080 , JPEG 3664 x 3664 , JPEG 2592 x 2592 , JPEG 1824 x 1824
Video Capture
AVCHD - 3840 x 2160 - 25 fps - 100Mbps , AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 i - 50 fps - 24Mbps , AVCHD - 1920 x 1080 i - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 20Mbps , AVCHD - 1280 x 720 - 25 fps - 10Mbps , H.264 - 640 x 480 - 25 fps - 4Mbps
11.2 cm
3.8 cm
6.4 cm
240 g
Optical Zoom: 30
Colour: Silver
Brand: Panasonic
Price Range Ex VAT: 150 - 300
