Panasonic CF-31 MK5 Intel Core i5-5300U 4GB 500GB 13.1" Touchscreen Windows 7 Professional 64-bit
Quicklinx: BHJ2WS00 Mfr#: CF-3140001CE
  • Core i5
  • Microsoft Windows 7 Professional
  • Bluetooth 4.0
  • IEEE 802.11n
Panasonic Toughbook 31 is the reliable laptop offering the highest performance in its class along with the world's most rugged design. Its Intel processor along with available discrete graphics, deliver desktop-class performance and improved video/3D graphics. The Toughbook 31 offers a 13.1" brilliant screen available with Panasonic CircuLumin technology. You have a computer that will go the distance with you anytime, anywhere.
Panasonic Toughbook 31 - 13.1" - Core i5 5300U - 4 GB RAM - 500 GB HDD
Notebook - rugged
Operating System
Win 7 Pro + Windows 8.1 Pro Licence
Intel Core i5 (5th Gen) 5300U / 2.3 GHz (2.9 GHz) / 3 MB Cache
4 GB DDR3L
Storage
500 GB HDD
Optical Drive
No optical drive
Display
13.1" LED backlight touchscreen 1024 x 768 / XGA
Graphics
Intel HD Graphics 5500
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Up to 18 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
30.2 cm x 29.2 cm x 7.35 cm
3.72 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Notebook - rugged
Operating System
Microsoft Windows 7 Professional + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel vPro Technology, Intel Smart Cache
RAM
4 GB
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Storage
Main Storage
500 GB HDD SATA 3Gb/s
Display
13.1"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1024 x 768 (XGA)
Widescreen
No
Sunlight readable, Outdoor
Audio & Video
Graphics Processor
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Sound
Speaker
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
Bluetooth Class
Class 1
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Single pass-through antenna
Lithium Ion
Max Supported Qty
2
8550 mAh
Run Time
Up to 18 hours
AC Adapter
Input
Output
15.6 V, 7.05 A
Connections & Expansion
Expansion Bays
1 x Multimedia Bay
Slots
1 x PC Card (1 free) , 1 x ExpressCard/54 (1 free)
Serial , VGA , HDMI , Headphone output , Microphone input , 3 x USB 2.0 , USB 3.0 , LAN , Aerial , Dock
Memory Card Reader
Yes (SD Card, SDXC Card)
Case Material
Magnesium alloy
Dockable
Security
Administrator password, system password, hard drive password, water-resistant, circular polarising, dust-resistant, anti-vibration, shock-resistant, resistive touch screen, handle
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, IEC 60529 IP65, MIL-STD 810G, IEC 60529 IPX5, MIL-STD 810G 514.6, MIL-STD 810G 516.6, MIL-STD 810G 510.5, JIS C 0920, IEC 60529 IP6X, MIL-STD 810G 506.5
3.72 kg
ENERGY STAR Certified
BHJ2 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BHJ2 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.58
BHJ2 C2G 5m Select High Speed HDMI with Ethernet In Stock £22.02
BHJ2 C2G 10m Select High Speed HDMI with Ethernet In Stock £42.28
BHJ2 C2G 15m Select High Speed HDMI with Ethernet In Stock £57.26
BHJ2 C2G Pro HDMI to VGA Converter In Stock £52.79
BHJ2 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
