Panasonic Toughbook 31 is the reliable laptop offering the highest performance in its class along with the world's most rugged design. Its Intel processor along with available discrete graphics, deliver desktop-class performance and improved video/3D graphics. The Toughbook 31 offers a 13.1" brilliant screen available with Panasonic CircuLumin technology. You have a computer that will go the distance with you anytime, anywhere.
- Panasonic Toughbook 31 - 13.1" - Intel Core i5 - 5300U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook - rugged
- Operating System
- Win 7 Pro + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (5th Gen) - 5300U / 2.3 GHz, up to 2.9 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L
- Storage
- 500 GB HDD
- Display
- 13.1" LED backlight touchscreen 1024 x 768 / XGA
- Graphics
- Intel HD Graphics 5500
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- Up to 18 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 30.2 cm x 29.2 cm x 7.35 cm
- 3.72 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Product Type
- Notebook - rugged
- Operating System
- Microsoft Windows 7 Professional + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5300U / 2.3 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel vPro Technology, Intel Smart Cache
- RAM
- 4 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s
Display
- 13.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1024 x 768 (XGA)
- Widescreen
- No
- Sunlight readable, Outdoor
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- Sound
- Speaker
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Bluetooth Class
- Class 1
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Single pass-through antenna
- Technology
- Lithium Ion
- Max Supported Qty
- 2
- Capacity
- 8550 mAh
- Run Time
- Up to 18 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 15.6 V, 7.05 A
Connections & Expansion
- Expansion Bays
- 1 x Multimedia Bay
- Slots
- 1 x PC Card (1 free) , 1 x ExpressCard/54 (1 free)
- Serial , VGA , HDMI , Headphone output , Microphone input , 3 x USB 2.0 , USB 3.0 , LAN , Aerial , Dock
- Memory Card Reader
- Yes (SD Card, SDXC Card)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Administrator password, system password, hard drive password, water-resistant, circular polarising, dust-resistant, anti-vibration, shock-resistant, resistive touch screen, handle
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, IEC 60529 IP65, MIL-STD 810G, IEC 60529 IPX5, MIL-STD 810G 514.6, MIL-STD 810G 516.6, MIL-STD 810G 510.5, JIS C 0920, IEC 60529 IP6X, MIL-STD 810G 506.5
- 3.72 kg
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
