Panasonic Camcorder Black FHD 2.51MP 50xZoom 3.0LCD WiFi SD/SDHC/SDXC
Quicklinx: C1FSWS00 Mfr#: HC-W580EB-K
Type: Camcorder
Media Type: Flash card
Optical Zoom: 50
Video Input: Composite video/audio, HDMI, USB 2.0
£201.41 ex VAT
£241.69 inc VAT
Easily capture distant objects that are too far away to shoot with conventional zoom functions - thanks to 90x Intelligent Zoom. You can also use the 50x Optical Zoom to zoom in on your subject to add more emotion and dynamics to your homemade footage. Fit more people and more of the background into the frame - the 28 mm Wide-Angle function (35 mm camera equivalent) makes it possible. This is especially handy when you want to take a group shot in a small room. It fits objects in even when you shoot from up close, and makes it possible to pick up even small sounds with the camcorder's built-in microphone. This model includes a rotatable sub camera that lets you take shots from two angles at once. For example, you can capture the family and a selfie, or both tele and wide-angle shots. A Backup function records a picture in picture image and a main camera image without a sub window for backup. The sub camera image is recorded into any one of various sub windows, and its display position can be changed by touch operation.
  • 90x intelligent/50x optical zoom
  • 28 mm wide-angle
    Fit more people and more of the background into the frame - the 28 mm Wide-Angle function (35 mm camera equivalent) makes it possible. This isespecially handy when you want to take a group shot in a small room. It fits objects in even when you shoot from up close, and makes it possible to pick upeven small sounds with the camcorder's built-in microphone.
  • Twin camera function
  • Wireless multi camera
    Enjoy a kind of shooting style that lets you add even more emotion to your movies. Using Wi-Fi, you can link to as many as three smartphones and simultaneously record up to two of them as sub-windows. These sub-window images can be interchanged, and their display positions can be switched. This lets you shoot from a variety of angles and viewpoints, to capture a higher level of emotional impact.
  • HDR (High Dynamic Range) movie
    Enjoy crisper, clearer videos thanks to the HDR Movie function. It combines two images taken with different exposures to suppress blown highlights and blocked shadows. Even in difficult shooting situations, such as backlighting, you can easily capture natural videos with excellent gradation. A dedicated HDR button enables quick mode changes when necessary.
Panasonic HC-W580 - camcorder - storage: flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
SD card
Wireless Interface
Wi-Fi
Sensor Resolution
2.51 MP
Effective Sensor Resolution
Video: 2.2 MP - Photo: 2.2 MP
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 50x zoom - 2.06 - 103 mm - f/1.8-4.2
Lens System (2nd)
Lens 2.48 mm - f/2.8
Focus Adjustment
Automatic, manual
Digital Zoom
3000x
Image Stabiliser
Optical (5-axis HYBRID O.I.S. + with Active Mode)
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1940 mAh (included)
6 cm x 12.9 cm x 6.2 cm
264 g
Camcorder - 1080p
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
2.51 MP
Sensor Qty
1 MOS
Effective Video Resolution
2.2 MP
Effective Photo Resolution
2.2 MP
Camcorder Interpolated Photo Resolution
10.0 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
BSI MOS
Optical Sensor Size
1/5.8"
Frame Rate (Max Resolution)
50 fps
Optical Zoom
50x
Digital Zoom
3000x
Video Recording Modes
HA, HG, HE, PH
Image Stabiliser
Built-in Optical Image Stabiliser
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
Digital Video Format
AVCHD, H.264, iFrame
Image Recording Format
JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
Connectivity Features
Remote control via mobile devices, remote live view, Wireless Twin Camera
Exposure & White Balance
Min Illumination
1 lux
Exposure Modes
Programme, automatic
Special Effects
Miniature, 8mm Movie, Silent Movie
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, sunlight, indoor
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/2 sec
Lens System
Focal Length Equivalent to 35mm Camera
28 - 1740mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Built-in lens shield
Lens System (2nd)
30.6mm
Rotating (270°)
Additional Features
Low Lux / Night Mode
Additional Features
Picture-in-picture capability, built-in speaker, takes photos while film recording, USB charging, Live Broadcasting, Intelligent Auto Plus (iA+), Dual Stream Encoding, Time-Lapse recording, Level Shot Function, Creative Control, Twin Camera function, Baby Monitor mode, home security video camera mode
Display
3" LCD display
Display Format
460,800 pixels
Display Form Factor
Rotating
Touch Screen
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom
Connector Type
HDMI output (19 pin mini HDMI Type C) , USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities, Panasonic HD Writer LE 3.0
AC power adaptor, USB cable, HDMI cable
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4224 x 2376 , JPEG 1920 x 1080 , JPEG 3408 x 2272 , JPEG 1728 x 1152 , JPEG 3136 x 2352 , JPEG 640 x 480
Video Capture
AVCHD - 1920 x 1080 p - 50 fps - 28Mbps , AVCHD - 1920 x 1080 i - 50 fps - 24Mbps , AVCHD - 1920 x 1080 i - 50 fps - 17Mbps , AVCHD - 1920 x 1080 i - 50 fps - 13Mbps , AVCHD - 1920 x 1080 i - 50 fps - 5Mbps , iFrame - 960 x 540 p - 25 fps - 28Mbps , H.264 - 1280 x 720 p - 25 fps - 9Mbps , H.264 - 1920 x 1080 p - 50 fps - 28Mbps
6 cm
12.9 cm
6.2 cm
264 g
Type: Camcorder
Optical Zoom: 50
Video Input: HDMI
Video Input: USB 2.0
Brand: Panasonic
Price Range Ex VAT: 150 - 300
