Panasonic 55" 1920 x 1080 Black Large Format Display
Quicklinx: C2T6WS00 Mfr#: TH-55LFE8E
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
31 in stock
£878.82 ex VAT
£1,054.58 inc VAT
The LFE8 Series features a USB media player. Signage operation is possible by simply inputting the desired content via USB, eliminating the need for a set-top box. Both videos and still images can be displayed, so a wide variety of original signage content can be used.
  • The slim bezel enhances viewing and replacement
    The bezel is about the same width all around the perimeter. This slim bezel design helps viewers concentrate on the screen image.
  • Built-in speakers are convenient for videoconferences
    The LFE8 Series features 10 W + 10 W built-in speakers. This eliminates the need for external speakers when displaying content with a sound track or when holding videoconferences. There is also no need to consider the space for the speakers when setting up the display.
  • Installs in just about any space
    This slim design allows effective space utilization in stores, showrooms and conference rooms. With a depth of less than 62 mm, it is also not oppressive when mounted on a wall.
Panasonic TH-55LFE8E LFE8 - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
170 Watt
Power Consumption (On mode)
130 W
Power Consumption Stand by
0.5 Watt
123.9 cm x 6.2 cm x 71.2 cm
16 kg
170 Watt
130 W
Diagonal Class
55"
Commercial Use
Series
LFE8
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode
Timer Functions
Power on delay
Design
Slim Bezel Design
Dimensions
Without stand
123.9 cm
6.2 cm
71.2 cm
16 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Backlight Life
50,000 hour(s)
Commercial Features
Input Search Function
Stands & Mounts
Stand
Optional
VESA Mounting Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver - 1.18 x 3.15"
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
2 x HDMI , DVI-D input , Audio line-in , Audio line-out , VGA input , Network , Serial , USB , Remote control input , Remote control output , Composite video input
2 AAA batteries, clamper
Power cable - 1.8 m
IEC 60950-1, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, IEC 62087 Edition 2, IEC 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
136.5 cm
Depth (Shipping)
14.5 cm
Height (Shipping)
86.4 cm
Weight (Shipping)
24 kg
20 - 80% (non-condensing)
Brand: Panasonic
Price Range Ex VAT: 750 - 1000
