The UB900 features a 4K High-Precision Chroma Processor equipped with imaging technologies such as chroma processing and high gradation processing that have been fostered and refined by the Panasonic Hollywood Laboratory (PHL) Blu-ray R&D facility.
By taking full advantage of the massive amount of Ultra HD Blu-ray data, the UB900 reproduces video images on a home TV that look exactly as their creators intended them to look.
The UB900 also offers dramatically improved audio quality. It is equipped with an optimized, large-capacity power supply unit and features many select high-quality audio parts and components in its audio circuits for rich sound expression. In addition, it supports high-resolution audio formats such as DSD and ALAC.
Amazing experience
The next-generation Blu-ray reproduction has arrived with high resolution and brightness range. HDR adds stunning gradation and contrast. Panasonic's advanced technologies further enhance picture quality to reproduce natural colors and delicate textures for a high level of viewing. -
Theater-level quality
The UB900 reproduces the finely nuanced colors and rich, detailed images that the film creator intended, and achieves lifelike surround sound. You can watch movies at home in comparable quality that you enjoy at cinema. -
High-resolution audio playback
The UB900 is designed for high-resolution audio reproduction. In addition to the conventional formats, DSD and ALAC music files can be reproduced. Simply connect to your home audio system to enjoy music sources equivalent to studio master sound quality. -
High-quality audio design
Everything from signal processing to output aims to achieve stunning sound quality. Large-capacity electrolytic capacitors provide powerful sound, and a Mica capacitor reduces digital noise from the power line.
- Panasonic DMP-UB900EBK - Blu-ray disc player
- Product Type
- 3D Blu-ray disc player
- Internet Streaming Services
- Netflix, YouTube, Internet Apps
- Home Network Media Sharing
- DLNA
- 43.5 cm x 19.9 cm x 6.8 cm
- 2.4 kg
- Media Type
- CD-R, CD-RW, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, DVD+R DL, BD-R, BD-RE, BD-ROM, DVD-R DL, BD-R DL, BD-RE DL, Blu-ray Disc, CD-DA
- BD Profiles
- Profile 2.0 (BD-Live)
- Media Format
- NTSC, PAL
- Upscaling
- Yes (up to 4K)
- Audio D/A Converter
- 32bit / 192kHz
- Remote Control
- Remote control - infrared
- Sound Output Mode
- Surround Sound
- Power
- AC 230V (50 Hz)
- Form Factor
- Tabletop
- Product Type
- 3D Technology
- Form Factor
- Tabletop
- 43.5 cm
- 19.9 cm
- 6.8 cm
- 2.4 kg
DVD
- Media Type
- Media Format
- NTSC, PAL
- BD Profiles
- 32bit / 192kHz
- Max Video Resolution
- 4K UHD Video Playback
- Media Load Type
- Tray
- Upscaling
- Yes (up to 4K)
- 4K Upscaling
- Video Formats
- MPEG-2, XviD, MPEG-4, MKV, AVCHD
- Audio Formats
- WAV, MP3, FLAC, DSF, DSD, ALAC, DFF
- Photo Formats
- JPEG, MPO
Network & Internet Multimedia
- Connectivity Interfaces
- IEEE 802.3 (Ethernet), Wi-Fi
- DLNA
- DLNA
Blu-ray & DVD Features
- Video playback from USB devices, VIERA Link, digital audio playback from USB devices, digital photo playback from USB devices, x.v.Colour technology, Deep Colour, Web Browser, external HDD (FAT/NTFS) compatible, Miracast support, Upscaling to 4K Direct Chroma
Audio System
- Sound Output Mode
- Surround Sound
- THX certified
- High-Resolution Audio
- Digital Audio Format
- Dolby Digital output, Dolby True HD digital output, Dolby Digital Plus output, DTS-HD Master Audio Essential output, DTS-HD High-Resolution Audio digital output
- Digital Tube Sound, High Clarity Sound Premium
Remote Control
- Remote control
- Remote Control Technology
- Infrared
- Connector Type
- 2 x HDMI output (19 pin HDMI Type A) , LAN (RJ-45) , USB 2.0 (4 PIN USB Type A) - front , Digital audio output (optical) (TOS Link) , Digital audio output (coaxial) (RCA) , Audio line-out (RCA x 2) , Audio line-out (RCA x 8)
Slots
- SDXC Memory Card
- Power Device
- Power supply
- Voltage Required
- AC 230V (50 Hz)
- 26 Watt
- Power Consumption Stand by
- 0.2 Watt
