Panasonic 4K UHD Blu-Ray Player
Quicklinx: C4LLWS00 Mfr#: DMP-UB900EBK
  • DVD
  • BD-R
The UB900 features a 4K High-Precision Chroma Processor equipped with imaging technologies such as chroma processing and high gradation processing that have been fostered and refined by the Panasonic Hollywood Laboratory (PHL) Blu-ray R&D facility.
By taking full advantage of the massive amount of Ultra HD Blu-ray data, the UB900 reproduces video images on a home TV that look exactly as their creators intended them to look.
The UB900 also offers dramatically improved audio quality. It is equipped with an optimized, large-capacity power supply unit and features many select high-quality audio parts and components in its audio circuits for rich sound expression. In addition, it supports high-resolution audio formats such as DSD and ALAC.
  • Amazing experience
    The next-generation Blu-ray reproduction has arrived with high resolution and brightness range. HDR adds stunning gradation and contrast. Panasonic's advanced technologies further enhance picture quality to reproduce natural colors and delicate textures for a high level of viewing.
  • Theater-level quality
    The UB900 reproduces the finely nuanced colors and rich, detailed images that the film creator intended, and achieves lifelike surround sound. You can watch movies at home in comparable quality that you enjoy at cinema.
  • High-resolution audio playback
    The UB900 is designed for high-resolution audio reproduction. In addition to the conventional formats, DSD and ALAC music files can be reproduced. Simply connect to your home audio system to enjoy music sources equivalent to studio master sound quality.
  • High-quality audio design
    Everything from signal processing to output aims to achieve stunning sound quality. Large-capacity electrolytic capacitors provide powerful sound, and a Mica capacitor reduces digital noise from the power line.
Panasonic DMP-UB900EBK - Blu-ray disc player
3D Blu-ray disc player
Internet Streaming Services
Netflix, YouTube, Internet Apps
Home Network Media Sharing
DLNA
43.5 cm x 19.9 cm x 6.8 cm
2.4 kg
Media Type
CD-R, CD-RW, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, DVD+R DL, BD-R, BD-RE, BD-ROM, DVD-R DL, BD-R DL, BD-RE DL, Blu-ray Disc, CD-DA
BD Profiles
Profile 2.0 (BD-Live)
Media Format
NTSC, PAL
Upscaling
Yes (up to 4K)
Audio D/A Converter
32bit / 192kHz
Remote Control
Remote control - infrared
Sound Output Mode
Surround Sound
AC 230V (50 Hz)
Tabletop
Blu-ray disc player
3D Technology
Tabletop
43.5 cm
19.9 cm
6.8 cm
2.4 kg
DVD
Media Type
Media Format
NTSC, PAL
BD Profiles
Audio D/A Converter
32bit / 192kHz
Max Video Resolution
4K UHD Video Playback
Media Load Type
Tray
Upscaling
Yes (up to 4K)
4K Upscaling
Video Formats
MPEG-2, XviD, MPEG-4, MKV, AVCHD
Audio Formats
WAV, MP3, FLAC, DSF, DSD, ALAC, DFF
Photo Formats
JPEG, MPO
Network & Internet Multimedia
Connectivity Interfaces
IEEE 802.3 (Ethernet), Wi-Fi
DLNA
DLNA
Blu-ray & DVD Features
Video playback from USB devices, VIERA Link, digital audio playback from USB devices, digital photo playback from USB devices, x.v.Colour technology, Deep Colour, Web Browser, external HDD (FAT/NTFS) compatible, Miracast support, Upscaling to 4K Direct Chroma
Audio System
Sound Output Mode
Surround Sound
THX certified
High-Resolution Audio
Digital Audio Format
Dolby Digital output, Dolby True HD digital output, Dolby Digital Plus output, DTS-HD Master Audio Essential output, DTS-HD High-Resolution Audio digital output
Digital Tube Sound, High Clarity Sound Premium
Remote Control
Remote control
Remote Control Technology
Infrared
Connector Type
2 x HDMI output (19 pin HDMI Type A) , LAN (RJ-45) , USB 2.0 (4 PIN USB Type A) - front , Digital audio output (optical) (TOS Link) , Digital audio output (coaxial) (RCA) , Audio line-out (RCA x 2) , Audio line-out (RCA x 8)
Slots
SDXC Memory Card
Power supply
AC 230V (50 Hz)
26 Watt
Power Consumption Stand by
0.2 Watt
