The LFE8 Series features a USB media player. Signage operation is possible by simply inputting the desired content via USB, eliminating the need for a set-top box. Both videos and still images can be displayed, so a wide variety of original signage content can be used.
The slim bezel enhances viewing and replacement
The bezel is about the same width all around the perimeter. This slim bezel design helps viewers concentrate on the screen image. -
Built-in speakers are convenient for videoconferences
The LFE8 Series features 10 W + 10 W built-in speakers. This eliminates the need for external speakers when displaying content with a sound track or when holding videoconferences. There is also no need to consider the space for the speakers when setting up the display. -
Installs in just about any space
This slim design allows effective space utilization in stores, showrooms and conference rooms. With a depth of less than 62 mm, it is also not oppressive when mounted on a wall.
- Panasonic TH-48LFE8E LFE8 - 48" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- VA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Input lock, button lock, remote control user level
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries, clamper
- Voltage
- AC 230V (50/60 Hz)
- 150 Watt
- Power Consumption (On mode)
- 105 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 108.2 cm x 6.2 cm x 62.4 cm
- 11.5 kg
- Product Type
- 150 Watt
- 105 W
- Diagonal Class
- 48"
- Commercial Use
- Series
- LFE8
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, 1:1 Pixel Mode
- Timer Functions
- Power on delay
- Design
- Slim Bezel Design
- Dimensions
- Without stand
- 108.2 cm
- 6.2 cm
- 62.4 cm
- 11.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Widescreen Modes
- Zoom
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Backlight Life
- 50,000 hour(s)
- Input Search Function
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Driver Details
- Main channel speaker: 2 x full-range driver - 1.18 x 3.15"
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Supported Consumer Electronics Control (CEC)
- PJ Link
- Connector Type
- 2 x HDMI , DVI-D input , Audio line-in , Audio line-out , VGA input , LAN , Serial , USB , Remote control input , Remote control output , Composite video input
- 2 AAA batteries, clamper
- Cables Included
- Power cable - 1.8 m
- IEC 60950-1, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, IEC 62087 Edition 2, IEC 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Width (Shipping)
- 119.2 cm
- Depth (Shipping)
- 17.1 cm
- Height (Shipping)
- 77.3 cm
- Weight (Shipping)
- 17 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
