Extremely bright images
Despite its light weight and compact dimensions, the PT-VW355NAJ outputs 4,000 lm of brightness for spectacularly clear and brilliant images. -
High 12,000:1 contrast
A iris mechanism optimizes light output according to content. Blacks are deep and rich while colors and highlights are reproduced with realism. -
Daylight view basic
Panasonic's daylight view basic technology achieves sharp, easy-to-see images by clearly reproducing the details in dark areas of the image, which were previously difficult to see in brightly lit rooms. A built-in sensor measures the ambient light, and daylight view basic function adjusts halftone color and brightness levels according to the surrounding illumination. -
Quiet operation
The quiet design keeps noise levels down to a low 29 dB on Eco mode with the cooling fan hardly audible, minimizing distractions during presentations. -
Low power consumption on standby
With Standby mode set to Eco, standby power consumption is a mere 0.5 W. This lowers running costs and helps to reduce environment impact.
- Panasonic PT-VW355NAJ - 3LCD projector - WiDi / 802.11a/b/g/n wireless / Miracast Wi-Fi Display
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 4000 lumens
- Contrast Ratio
- 12000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), Intel Wireless Display (WiDi) / IEEE 802.11a/b/g/n wireless / Miracast Wi-Fi Display
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 320 Watt
- 35.2 cm x 27.94 cm x 9.8 cm
- 3.4 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- 802.11a/b/g/n, Ethernet
Projector
- Brightness
- 4000 lumens
- Contrast Ratio
- 12000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.18 - 1.9:1
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Video Bandwidth
- 162 MHz
- Display Format
- 1,024,000 pixels
- Max Sync Rate (V x H)
- 100 Hz x 100 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, Auto Input Search, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, 3LCD Technology, Auto Vertical Keystone, Deep Color, PJlink, AMX Device Discovery, Direct Power Off, Colourboard Mode, Dynamic Mode, Real-Time Keystone Correction, Crestron Connected, USB Viewer, USB Display, Eco Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6-1.9
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -40 / +40
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- WiDi, Miracast, Wi-Fi
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel - 4 cm
- 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
- Included Accessories
- 2 x AAA batteries, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 320 Watt
- Power Consumption Stand by
- 14 Watt
- Software Included
- Logo Transfer Software, Multi Projector Monitoring & Control Software, Wireless Manager Mobile Edition 6.3
- 35.2 cm
- 27.94 cm
- 9.8 cm
- 3.4 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
