OtterBox iPhone SE (2nd gen) and iPhone 8/7 Symmetry Series Case
Quicklinx: CCZLWS00 Mfr#: 77-53947
Device Type: iPhone 7 / 8
Type: Case / Cover
Product Range: OtterBox Symmetry Series
Product Model: Apple iPhone 7/8
More than 50 In Stock
£13.93 ex VAT
£16.71 inc VAT
Slip into the sleek case for stylish protection that expresses your personal style compatible with both iPhone 7 and 8.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
  • Stylish designs: eye-catching colors dress up your device
  • Slim profile: sleek design slips easily into pockets and purses
  • Screen bumper: raised, beveled edge helps protect touchscreen
  • Easy installation: one-piece design slips on and off in a flash
OtterBox Symmetry Series Apple iPhone 7 - back cover for mobile phone
Back cover for mobile phone
Material
Polycarbonate, synthetic rubber
Apple iPhone 6, 6s, 7, 8, SE (2nd generation), SE (3rd generation)
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch-resistant, drop-proof
Cover Type
Back cover
2 years
Type: Case / Cover
Brand: OtterBox
