OtterBox Symmetry for iPhone 5/5s/SE - Rosso Corsa Red
Quicklinx: D1DXWS00 Mfr#: 77-53657
Symmetry series is the culmination of over a year of design, testing and innovation. This sleek, cleanly constructed protective smartphone case is simple to install in its one-piece form. But don't let its elegant simplicity fool you - the dual-material construction makes Symmetry series one of the slimmest, most protective cases in its class. The raised beveled edge helps keep the touch screen safe, while the internal material and honeycomb coring help protect the smartphone from drops and shock. A full spectrum of wraparound colors and graphics on the sleek exterior add seamless style to complete your entire look.
  • Style and protection collide
    This sleek, cleanly constructed case is simple to install in its one-piece form. But don't let its elegant simplicity fool you - the dual-material construction makes Symmetry series one of the slimmest, most protective cases in its class. Symmetry series for iPhone has the style you want with the protection you need.
  • Style matters
    When it comes to your smartphone, it's not just about the protection. It's also about you - your style, your personality, your life.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone
Material
Polycarbonate, synthetic rubber
Rosso corsa
1-year warranty
Material
Rosso corsa
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch-resistant, drop-proof
Cover Type
Back cover
1 year
