OtterBox Symmetry Duo for Surface Pro (2017) / Pro 4 / Pro 6 - Slate
Quicklinx: FCCWWS00 Mfr#: 77-57444
Colour: Slate grey
Stock Status: Used Stock
£30.32 ex VAT
£36.38 inc VAT
Slim, clear case keeps your tablet safe for peak productivity. Two-piece design protects both your tablet and the keyboard. Slip your tablet into the sleek Symmetry series case and use your tablet everywhere with confidence.
  • Slim profile
    Precision design provides perfect form, fit and function.
  • Defends tablet and keyboard
    Accommodates quick keyboard attach and detach functionality.
  • Allows smooth use of kickstand
    Adjust your tablet to the ideal position with smooth use of the kickstand.
OtterBox Symmetry Series - flip cover for tablet
Flip cover for tablet
Material
Polycarbonate, synthetic rubber
Slate grey
Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6
Material
Slate grey
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Drop-proof, tear-resistant, wear-resistant
Cover Type
Flip cover
Open Type
Side
Cover Features
Stand function
OtterBox Symmetry Duo for Surface Pro (2017) / Pro 4 / Pro 6 - Slate Bundle deal on OtterBox Symmetry Duo for Surface Pro (2017) / Pro 4 / Pro 6 - Slate
£129.49
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FCCW 041316
Condition: Customer return - item has been used and shows signs of use. Not in original packaging.
This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  £6.24
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Colour: Slate grey
Brand: OtterBox
Price Range Ex VAT: 0 - 50
