OtterBox React + Glass iPhone 15 Plus - Clear
Quicklinx: HFR0WS00 Mfr#: 78-81236
Device Type: iPhone 15
Type: Case
Product Range: OtterBox React Series
Product Model: [N/A]
£15.74 ex VAT
£18.88 inc VAT
Ultra-thin, resilient React Series case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case is easily installed, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series. OtterBox Glass screen cover installs easily and helps protect your display against drops, breaks and scratches. The glass resists smudges and fingerprints while it maintains the vivid clarity of your display.
REACT Case
- Ultra-thin case
- Made with more than 50% recycled plastic
- Easy on and off
- Wireless charging compatible
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
OtterBox Glass
- Drop defense for shatter resistance
- Scratch protection
- Fingerprint resistant
- Flawless touch response
- Quick & easy install kit
- Extra layer of durability
- 9H surface hardness
- Maintains screen clarity
  • Enhanced durability
    Experience peace of mind with the OtterBox React Series case, featuring DROP+ technology and compliance with MIL-STD-810G 516.6 standards. This protective cover is designed to withstand drops, bumps, and shocks, ensuring your cell phone remains in pristine condition.
  • Sleek design
    The one-piece design of the OtterBox React Series case combines ultraslim construction with soft touch edges, offering a comfortable grip without adding bulk. Its sleek profile maintains the phone's aesthetic while providing full protection.
  • Convenient charging
    Never compromise on convenience with the OtterBox React Series case. Designed to support wireless charging, it allows you to power up your device without removing the case, ensuring protection at all times.
  • Eco-friendly choice
    Make a positive impact on the environment with the OtterBox React Series case. Made of 50% recycled plastic, this case not only protects your phone but also contributes to reducing plastic waste.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
8.276 cm x 1.066 cm x 16.588 cm
41.18 g
Material
Plastic
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Plus
8.276 cm
1.066 cm
16.588 cm
41.18 g
Material
Plastic
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection, scratch protection, fingerprint-resistant, scrape protection
Cover Type
Back cover
9H tempered glass screen protector
Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
MIL-STD-810G 516.6
Type: Case
Brand: OtterBox
