OtterBox Power Bank 5K mAh USB A&C 12W Black
Quicklinx: JBL7WS00 Mfr#: 78-80641
£11.38 ex VAT
£13.65 inc VAT
OtterBox Standard Power Banks are engineered to charge and empower your day. USB-A and USB-C ports allow for multi - device charging, while the portable size is perfect for quick charges on the go. The pocketable OtterBox Standard Power Banks are thoughtfully designed with industry - leading mobile expertise and proven quality that is uniquely durable - to build trust, foster connections and instill confidence for whatever the day brings.
OtterBox Standard power bank - USB, 24 pin USB-C
Power bank
13.2 cm x 6.9 cm x 1.1 cm
135 g
Nearly night
Output Connector Type
Total 2: USB, 24 pin USB-C - on cable: USB-C
5 V
Voltage Provided
5 V
Fast Charge Technology
Apple Fast Charge, Samsung Adaptive Fast Charging, USB Battery Charging 1.2
5000 mAh
Power Device Details
Power bank - 24 pin USB-C - output - 5 V - 12 W - 2.4 A , Power bank - 4 pin USB Type A - output - 5 V - 12 W - 2.4 A
Cables
USB-C to USB-A cable - 15 cm
Power bank
13.2 cm
6.9 cm
1.1 cm
135 g
Enclosure Colour
Nearly night
5 V
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
Detachable Cable Connector Type
USB-C
Power bank: 24 pin USB-C - output - 5 V - 12 W - 2.4 A , Power bank: 4 pin USB Type A - output - 5 V - 12 W - 2.4 A
Power LED Indicator
5000 mAh
Limited warranty - lifetime
Brand: OtterBox
